Question about Kenmore 24 in. 15932 Built-in Dishwasher
I have a kenmore 15951793 it refuses to drain. I've metered the drain line into the motor and it is there but it will attempt to run but seems to trip a thermal breaker. the motor doesn't turn at all but the motor shaft is free, so I'm assuming bad coil. Any thoughts??
2 Suggested Answers
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Kenmore ultra wash model 15951793 sani wash flashing
what is your model number is then we can get started then
Jan 04, 2013 | Kenmore 24 in. 16032 Built-in Dishwasher
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
Hello all I have been getting the F21 error code (seems to be a popular error) I cleand the drain on the pump as I was cleaning debris out i noticed the motor impellar was cracked so I replaced it. ...
My WAG would be yes, something is still in the drain line. Especially since enough debris has been through it to crack your impellar.
Have you tried running a guitar string up to see if you can dislodge any blocks.
Jun 09, 2011 | Kenmore Washing Machines
Kenmore Dryer #110.667126
the door has a kill switch in the door jamb
replace that
Mar 05, 2010 | Kenmore 63942 Dryer
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
F 02
Although you have cleaned out the drain pump, you still may have a clog in the drain line somewhere, or you have a pump that has failed. A noteable area that gets clogged often with small articles of clothing (such as wash cloths, socks, underwear, etc.), is the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump. If you have checked this, the pump clean out reservoir, and all remaining drain lines after the pump, you more than likely have a defective pump. It doesn't take much to damage them, and just because you can hear it running, does not necessarily mean it is working properly. Often, the impeller blades are damaged, impeller shaft becomes stripped, or pump motor windings are worn. The best solution the manufacturer offers is to replace the drain pump. Searspartdirect.com carries the part. Just type in your complete model number and the drain pump will be located under the "Pump and Motor" heading as item 10 (I believe). The pump is sold as a complete assembly which includes the pump housing and the motor. If you need instructions on how to replace the pump, just click on this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
If you still don't believe me and wish to doublecheck your efforts before purchasing any replacement parts, the next link explains the "F02" error and how to attempt to correct it:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information is helpful to you. Let me know if you require additional assistance.
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
