Question about Refrigerators
I have a GE Profile Frig. Frig on top freezer on bottom Model #PDS22SBSBRSS The bottom of the freezer is collecting water and freezing. I have noticed a water stream coming from the far right back wall cover part # WR17X11594 EVAP FAN CVR ASM. The water is coming from the bottom of the cover to the right of the right louver, between that louver and the corner of the cover. Any ideas would be helpful I also am not sure how to remove this cover if necessary. Thanks for the help. Tim
  • Bar Johnson Sep 02, 2010
    How do I remove the inside back cover? I don't want to braek it.
    Does it pop out or do I have to remove screws?
  • 2,382 Answers
Hi, it sounds like drain iced up in freezer section. if you can turn cab off, remove back panel inside freezer section, allow ice in drain to thaw, use hairdryer to speed up defrosting, be careful, water and electricity dont mix. Usual cause is partially blocked drain hole. Also check the following, if drain area has a seperate defrost heater make sure it is working and if self adhesive foil type it should be in good condition and in good contact with drain pan. At the back of cab check drain hose for holes and splits and ensure good drain trap and/or correct operation of drain non return valve.
Posted on Sep 02, 2010
  • Tunde Autos
    Tunde Autos Sep 02, 2010
    It is very fragile and delicate to remove, so you have to be very careful or else get a fridge tech to help out....
  • Tunde Autos
    Depending on the model, some use screws will some pop out..
    You have to see if there are screws to loosen up and if there are none, you try to pop it out...
Ge profile refrigerator model number tfx30pry
You have a clogged drain system in the freezer, as the unit will defrost daily, the water can't leave the freezer properly and the water collects. You need to de-ice the freezer and clean out the drain tube at the bottom of the freezer section under the evaporator. Good Luck
Jul 20, 2014 | GE Refrigerators
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
