Question about Sanyo PLC-SW30 Multimedia Projector
I turn the remote receiver off
I was browsing the menu in the projector and acidentally i turned the remote control off.now i cant turn it on.
  • pikachu1112 May 11, 2010
    Have you checked the batteries in your remote? If you did, you probably may have to change your batteries. Turn on the remote and go back to the menu to make sure it works.
  • 4 Answers
I think he turnerd the remote sensor off in the menu, if you did, press the menu button on the projector itself and then go find the sensor options to turn the recievers on.  Hope this helps!
Posted on May 11, 2008
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Sony LCD Projector
NOT HAVING REMOTE??...INTRESTING...
HAVE YOU TRIED IT MANUALLY TO TURN IT ON??
Mar 15, 2008 | Sony VPL-ES3 Multimedia Projector
I replaced the lamp in my 46HM95 and as soon as I turned it on, the screen flickers. Any ideas?
Reset the lamp hour meter. Unplug the unit in the main power outlet then turn on the main power switch on. Press and hold the ON, stand by, menu and Input buttons at the same time the buttons are on the projector. Though the same buttons are found on the remote control, the reset only works with the projectors buttons.Plug the power cord back in to the outlet while holding the buttons ON, STANDBY, MENU, INPUTS buttons at the same time, the lamp timer will reset when the projector receive power. Good day and best regards.
Aug 13, 2011 | Toshiba 46HM95 46" HDTV
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
Trying to setup the Panasonic PTL 720U, accidentally turned off the control key to OFF in the menu and now cannot access Menu or another other options. How do I reset back to factory or so I can access the...
In order to set the CONTROL KEY to "ON" without
using the remote control unit, keep holding down
the ENTER button on the projector and press the
MENU button for more than 2 seconds. It will then
be turned ON.
Feb 12, 2011 | Panasonic PT L720U Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Would not turen back on
It sounds like you changed the remote code, which shuts the remote control off. Can you get into the menu using the controls on the projector itself? If you can, find the remote function and turn it back to the the original code. The factory set code is "code 1", this should get the remote back to normal use.
Good Luck
Jul 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Menu screen won't come up on screen
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding
down the ENTER button on the projector and press the MENU button for more than 2 seconds
Mar 27, 2009 | Panasonic PT-LB30U Multimedia Projector
Sanyo PLC-SW30 Multimedia Projector Logo
98 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
