I need a schematic for an Ativa 006990XA. My husband pulled the lid off the shredder to put. There is a square black plastic piece with a metal contact that is attached by wires. I don't know where it is supposed to go.
    Top Expert:
  • Office Equip... Master
  • 75,822 Answers
We have no diagrams of this type of machine, u will need to contact Ativa customer support, here is a link to the support page on line.
http://www.ativaproducts.com/contact.html
Posted on Sep 02, 2010
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
I placed less than 12 sheets of paper in the ativa 1250 shredder. it's reading overload. can you help?
The problem seems to be the plastic gears and/or bearing supports. Unless it is in warranty, it's going to cost you more to repair than replace, and even then Ativa's customer service is not the best and neither are their shredders: I suggest you look at http://www.complaintsboard.com/complaints/ativa-paper-shredder-c31646.html?page=2
Jun 29, 2014 | Office Depot Ativa DQ60M Shredder
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
Missing piece of shredder
Go back to the supplier you bought the machine from and tell them what you want.
Jun 23, 2010 | Office Equipment & Supplies
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Ativa shredder
Pull out as much of the paper as possible. Then spray some window cleaner or similar on whats left to soften and disolve it.
Dec 29, 2007 | Office Depot Ativa DQ60M Shredder
53 people viewed this question
k24674
