Question about Gigabyte Computers & Internet
Hello Sir I have a problem on GA-945GCM-52L Motherboard, The Motherboard doesn't work on SATA H.D.D and running very slow with IDE H.D.D, i tried change H.D.D but its same no use and also the H.D.D that i connected to the damaged mothers with another Gigabyte motherboard then its Working , i want to know what have to do to fix my problems please reply With Regards Mr. Sidheeq.V from Jeddah Saudi Arabia
  • 87 Answers
SOURCE: SATA DVD drive not found in BIOS
well as far as i studies ur problem ur 1st problem myt b bios updating do it wid successfull results den another iz i guess jumper settings n may b ur sata cables have some problems too, just do a check on these things make ya jumpers auto i mean remove it will be master automatically
n den let me know what happned!
Posted on Nov 17, 2007
  • 474 Answers
SOURCE: re on MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard
You have two SATA connectors but only need one SATA hard Drive. It has two because Gigabyte has a optional RAID setup. Some have 6, it depends on the nodel.
Alright, i looked it up online.
First, It has Dual Channel DDR which means you have to have two sticks of memory the same amount of memory on each stick, or just one. Whichever, you cant mix up different speeds or different size memory stix.
You need to have a SATA Hard Drive not IDE as this model appears to be SATA only. The IDE is meant for the CD Drive.
Is that your Board? Or close? the link is to the website.
Did you get this new? how old is it? This board is meant for setting up a raid system so if its not what you intended, get a smaller or less expensive board. Take it back and say it didnt fit your case just didnt meet your specs that you thought.
Posted on Dec 03, 2008
  • 95 Answers
SOURCE: setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
Posted on Mar 29, 2009
  • 666 Answers
SOURCE: Does the Gigabyte GA-K8VM800M support sata2? i
no it does not support sata
Posted on Mar 30, 2010
  • 4044 Answers
SOURCE: I have a Gigabyte Motherboard, I am running SATA
Your post doesn't list the specific motherboard being used however, if this is an option, and it might be, it is an option set in the Bios. The SATA drive is a faster drive and would be a better choice as Primary drive however, if there was an option in the BIOS for selecting which would be primary and which would be slave it would be in your BIOS options.
Posted on Nov 18, 2010
Can 500gd hard disk be connected to gigabyte 945gcm-s2l?
Yes you can, there won't be any problem install 500GB hard disk on your motherboard. It is recommended to use SATA type Hard Disk Drive instead of the old IDE/ATA.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 07, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Hi my friend: please help me for select HDD. 945GCM-S2L Max HDD Support? 945GCM-S2L <- this mainboard supported 2TR Byte?
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
Mar 15, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Will GA-945GCM-S2L support 500gb hard disk
Hard SATA 3 connect with GA-945GCM-S2L Do you support? yes or no
Feb 16, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided;
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
What kind of hardesk can installed to it sata or ide
This motherboard can use a SATA or IDE hard drive since it has connector for both SATA and IDE, but I suggest you use SATA hard drive for faster data transfer.
You can check this link for the complete specs for this motherboard.
Aug 08, 2010 | Gigabyte GA-8I945P-G Motherboard
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
