Question about Whirlpool Refrigerators
The freezer/fridge smells like trash. I can not locate the drip pan
Boba
  • 64 Answers
SOURCE: I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Posted on Jun 11, 2006
  • 111 Answers
SOURCE: WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Posted on Dec 20, 2008
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
  • 744 Answers
SOURCE: Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Posted on Apr 15, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Does this fridge have a drip pan
All fridges have a drip pan. Pull your fridge away from the wall, pull the lower cover off, and you will be able to locate it with a flashlight
Aug 04, 2016 | Igloo Cooler Igloo - 10.0 Cu. Ft....
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Foul smell coming from behind the refrigerator. I smell it coming through the fan on the back of the refrigerator. I believe it could be the drip pan, but I don't know where it is located. Also, my...
the drip pan is usually on top of the compressor or has a draw underneath with a coil to create heat for evaporation of water from the drip pan. Some time a rodent can drown in this location.
Jul 17, 2017 | Whirlpool GB2SHDXP Bottom Freezer...
How to get a smell out of a hotpoint fridge.we try bread soda.what else can we use
You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Feb 02, 2011 | Refrigerators
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
350 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
