Question about Toshiba 42HM66 42" Projection HDTV
Turns on and runs for about an hour then shuts off
    President:
  • 1,284 Answers
How long has it been since you replaced the lamp? Another suggestion would be to take the back off and CAREFULLY vacuum out the dust.
Posted on Sep 02, 2010
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
My cuisinart conical burr coffee grinder has started to turn it's self on every few hours
Electronic failure. If you like the grinder, plug it into a plug-in timer that only allows it to run when YOU want it to run. I have a timer like that on my coffeemaker so we don't forget to turn it off & let it run empty all day long. There are cheap timers available that will turn on for three hours if you push a little button, then shut off until next time you push the button. VERY handy, and they give you a selection of one hour, three hours, or six hours. For your purpose, one hour sounds fine. Or a wind-up type timer that stays on for only fifteen minutes, just long enough to grind coffee. Or unplug it when you're done. Or put it on a power strip with a switch.
Aug 01, 2014 | Cuisinart Conical Burr Coffee Grinder
Fuel pump wont shut off
Read page 19 of your owners manual. It's supposed to run about 5 hours after the car is shut off. I heard the same noise and googled it and found a response in one of the blogs. It's supposed to be an "Evaporation Leakage Check"?? To me, this seems to be something Toyota added to cover up a problem they found in their fuel system. Once you turn the key on and off, it will shut off, but likely will come on in another 5 hours.
May 05, 2012 | 2012 Toyota Camry
It runs fine for about an hour and then shuts off. I can turn it back on and it is fine for about another hour and then shuts down again.
Since the unit runs for an hour I would say the circulating fan and cover are dirty. This will cause an overheat. Also make sure the louvers are open in the front.
Tom
Mar 05, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Computer shuts off
Check to make sure Hibinate Mode is not turned on or Sleep mode
Apr 04, 2009 | Computers & Internet
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Toshiba 42HM66 42" Projection HDTV Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
