Question about Maytag Dryers
Electric dryer runs but does not heat. I pulled out the heating element and can read continuity through the coil, does that mean the element if fine and the problem is elsewhere?
  • rhernande1 Sep 02, 2010
    What is the proposed test, apply 220volts to the element & see if it opens? If not the element, what would be the logical cause of the problem?
    Top Expert:
  • Maytag Master
  • 80,637 Answers
Hello and welcome to Fixya! that type of a static test doesn't rule out the element going open as it heats up, which is likely the case here
Posted on Sep 02, 2010
  • yadayada
    yadayada Sep 02, 2010
    yes that would be the only active way of testing, be careful
Pulled out heating element both black wires connecting heating element are burned is this mean its a faulty heating element
Hi franklin bai
Yes the element is faulty...replace it...but also check some other things...see below
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Apr 16, 2011 | Amana NDE2335AY Electric Dryer
My Bosch dryer is running but there is heat?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 04, 2011 | Bosch Nexxt 500 Dryer
The dryer still runs but want get hot
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 28, 2010 | KitchenAid KEYS750LQ Electric Dryer
The dryer is running but will not heat
Nov 25, 2010 | Dryers
I have a Whirpool Dryer model 3LEN 2000PW1 It runs but does not heat?? Four years old. Could it be the heating element?
Hello there:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 29, 2010 | Whirlpool Dryers
DRUM TURNS BUT NO HEAT
Hi,Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
May 05, 2010 | Whirlpool Dryers
Brand new dryer will run and tumble but has no heat!
Hi, Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Apr 22, 2010 | Whirlpool LER4634J Electric Dryer
The dryer runs, but is not getting hot. Is there
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
No heat from dryer
It is most likely the heating element. If you would like to access the element, just take the 3 screws out of the bottom of the kick plate below the door and you will see the element in a canister. There should be a screw on the side of the canister that holds the element in. Remove this screw and pull wires off the element, after you have noted where the wires to the element are properly placed. Then proceed to pull the element straight out of the canister. Inspect the wire coils for breakage, If you find a broken coil wire, replace the element. If you do not find a broken coil wire then proceed to checking the high limit cut off thermals located on the side of the canister for continuity. If you find one of the thermals not to have continuity, replace both thermals. They come in a package together as one kit. Hope this helps. Dave
Mar 30, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer runs with no heat
An open circuit does mean the element is bad and will need to be replaced.
Just in case though, make sure your meter is working properly by touching the leads together. You should get a reading.
Mar 25, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
