Question about Thermos Grill2Go Fire+Ice
Grill will not go up when you step on foot pedal. seems grill to heavy! what kind of adjustment is needed?
I am having the same problem. If I take the grill off and press the pedal the hydraulics work and the arms raise, but when the grill is on it won't lift - as if it's too heavy. I was wondering if it just needed some WD-40.
Posted on Sep 08, 2010
Clutch adjustment
To work efficiently, the clutch needs the right amount of play in the linkage between the foot pedal and the clutch operating lever. OBD diagnostic tool one stop supplier
Feb 27, 2014 | 2000 Ford F-150 - XL, with bar style...
When I take my foot off the pedal it rewinds farther than it should
Hello on a BM-147 there is only one adjustment responsible for auto back space when you used foot pedal and that adjustment is next to the Display is call Reverse Time that controls the reverse function when you take foot control off from play but if the problem is when you take the foot off on REW and unit keeps going you have a bad foot pedal you can get a replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
May 17, 2011 | Sony BM-147 Desktop Cassette Transcriber /...
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
Bought this used in good shape cant get the grll to go down and looking for manual
As far as how to lower: Step (and hold down) the foot pedal, while holding the pedal down, push the grill down evenly on both sides at the same time. Let off the pedal when the grill is all the way down. I have two of these grills and love them. One will not stay down and I am working through that now. I'll post if I figure out the adjustment. Happy grilling, Don
Apr 23, 2010 | Thermos Grill2Go Fire+Ice
Loud clicking noise and black smoke...
Seems like an injector and valves. Check if all injectors are giving same pressure, none leaking or damaged, the injector pump working fine and all filter in the pump are clean (yes there are small filters inside under every electro-sensor), get valves gaps checked and adjusted. at this kind of mileage its a must.
Jan 02, 2010 | 2006 Volkswagen Jetta
Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Apr 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Problem with playback using foot pedal
you probably have a broken pedal here is one in a great price
Or if you feel better to send unit to service try this.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Feb 06, 2009 | Sony BM-147 Desktop Cassette Transcriber /...
Thermos Grill2Go Fire+Ice Logo
287 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
