Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w23 glue ghost shadow shows when I am watching tv. When I trey to perform a convergence the top half is leaning to the left and the bottom half is leaning to the right. So, I'm not able to get it lined up with the cross. What is wrong?
  • Anonymous Jul 15, 2008
    I have the same problem. where is it located and how hard is it to replace
Hello slinteriors, is there any place where i can find a replacement power board for the same TV as above? to be more specific i have a d52w17. If you can email me that would be great nickl@ grolen.com
Posted on Aug 11, 2008
I see double on my tv and everything is blue green and red. could this be the same issue?
Posted on Jul 01, 2008
  • RCA Master
  • 8,617 Answers
You will need a new convergence board as that model doesnt have the conventional ICs so the entire board must be replaced. let me know if you need further info.
Posted on May 10, 2008
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Tip
Good day!!!I i had problems with the fl 231 fuse on my RCA D52W23 proj.tv....i...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 14, 2009 | RCA R52WH73 Projection Television
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
What is the part # for a rca hd tv convergence ic. model # d52w23 & where is it available .picture concaving ay top & bottom,colour out of whack.
The part number for the convergence ic's are on the ic, they all start out with stk392-??? if it is a 110 thorugh a 150 you can use a stk392-180 to replace the orignal one, if it is a 560 you must use the same stk392-560 ic.
Sep 01, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
Rca d52w23
if u press menu on remote control and scroll down to set up , press ok and see convergance as an option choose it and adjust convergance.(lines up your colors) if u do this and convergance does not even show on your menu at all anywhere! like mine, then u have an open fuse for convergance board. mine is going to shop for this today.
Sep 17, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
234 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
