Question about GE WHRE5260E Top Load Washer
How do I get access to the drain pump and other internals?
  • GE Master
  • 8,220 Answers
Use a putty knife between the top and front panel How do I get access to the drain pump and other - dcd33c9.jpgThis video shows how to access the innards of a newer model GE than yours but yours is basically the same thing with a diff motor and tranny.
Posted on Sep 02, 2010
Testimonial: "Thank you for your info it answered my question and saved me hours of work that would have been spent attempting to get into the unit."
  • Dan Webster
    Dan Webster Sep 02, 2010
    Here is the video
  • Dan Webster
    OK I am gonna try to post the video for the 3rd time LOL I hate computers.
HOW TO REPLACE A OIL PUMP ON A 1997 FORD ESCORT L?
the oil pump is internal to the engine and can be accessed by first draining the oil ,remove the oil pan/sump then you can replace the pump,also change the filter at the same time and make sure you clean the old gasket off before fitting new
May 13, 2014 | 1997 Ford Escort
How you can replace the water pump motor for wm2277hs washer
Hi Maria.
The pump is located in correspondence of the front bottom side of the machine. Behind the pump filter access.
The pump is screwed to the internal side of the chassis. The procedure to replace the pump is illustrated here.
Aug 13, 2012 | LG WM-2277HW Front Load Washer
Coins in the drain pump
If it's a top loader and the pump is easily accessible, I would dismantle/have the pump dismantled and the objects removed. Othrewise they can cause future damage internally!
May 08, 2012 | Maytag Washing Machines
IS IT NECESSARY TO CLEAN THE PUMP TO MAKE THE WASHER DRAIN
Yes and they do not make it very convenient to do so. There is no clean out access to this pump. You must remove the hoses to access the internal working of the pump. Make sure you have plenty of towels available it is messy.
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Maytag MAH2400A Compact Front Load Washer
How do i change a 2004 Lincoln LS fuel pump?
Hi. here's how to change the fuel pump. The actual electric fuel pump is in the tank on the right side. The tank is directly below the rear seat. If you remove the seat bottom you will find a 6 inch or so cover. Under the cover there is a plastic, threaded collar that locks the fuel pump into the tank. The driver's side also has a pump, but it works only my venturi effect from the electric pump on the other side. This pump is used to equalize the fuel level from left to right. The drive shaft tunnel prevents all but the very top of the tank from communicating left to right.
Aug 12, 2010 | 2004 Lincoln LS
Makes a buzzing sound about half way through the
Does the water drain out at all if not then this is certainly a blockage in the drain pump and the dish washer will normally have to come out to get at drain pump the normal access to pump is through the base will have to tip unit on its back and remove base plate if it has one.Do check in bottom of internal filter for debris but it seems as if it has got into pump and stopping it turning.Hope this helps.I dont recognise the model number,is it correct.
Good Luck
May 07, 2010 | Electrolux 24 in. EDW5505EPS Stainless...
How to clean pump filter on lg wm2688hwm
No, probably have a bad water pump, very common for this washer. I would pull the washer out, lean it against your wall, brace or block it up so you can crawl under it. You will see where the drain hose comes out of the bottom left of the drum and enters the drain filter. Remove the hoses and check for debris or clothes in the hoses or where the drum outlet is. If no restrictions then replace your water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | LG WM2688HWM TROMM SteamWasher
Machine will not drain and registers a Ld display as fault. Is the drain motor burned out?
Hi. Essentially, this will indicate that the drainage assembly is obstructed. There may be a clog at the drain filter, or in the drain hoses. The worst scenario will be a damaged pump motor. I would check the hose Assembly first. Gain access to the pump and hose Assembly. This will require you to disassemble the cabinet, of course. Once exposed, disconnect the pump hoses, and check for foreign materials inside the hoses, and pump housing, as well. If the pump is belt driven, it will not be able to be opened, for internal inspection.
If it is a direct drive pump(on board motor), You will be able to open the housing. This will allow you to inspect the pump impeller for damage. If all is well with the hoses, and drain filter, the pump will be the culprit.
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Unit in basement leaking around bottom
The drain line coming from the internal drain pan to the pump is clogged, causing overflow of the internal pan. That means the water never reaches the pump, and is simply overflowing into the bottom of the unit/duct.
The drain line and pan need to be cleaned and cleared.
A shop vac is a wonderful tool for such a job.
Sep 23, 2009 | Whirlwind FH-778 Air Conditioner
SHX46L05UC Dishwasher
You cannot access the drain hose "internally" you will need to pull out the dishwasher and probably on the left side if facing underneath the drain hose will be connected with a screw clamp most likely.
Feb 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE WHRE5260E Top Load Washer Logo
247 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
