Question about Danby DKC645BLS Compact Beverage Cooler
I have a Danby DKC645BLS SERIAL # 0105030101336 Purchased about 4+ years ago I cannot set the temperature using the front keypad and neither can I change from Farenheight to centigrade. The compressor runs and the temperature keeps on increasing and not cutting out Last night LE appeared on the keypad display. When I disconnected the power the temperature dropped and the keypad display showed a number which I assumed was the temperature in centigrade Internal fan motor runs ok I am not sure what the problem is Can you help please? I live in San Diego CA John Trimmer
SOURCE: Danby DKC645BLS Tap is Jammed
The sugars in the beer are causing it to stick, if you don't use it regularly it dries stuck. You can sometimes gently force it, but it would probably be better to disassemble and soak the tap.
Posted on Aug 17, 2008
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
SOURCE: need a parts list for
I can obtain part breakdowns and replacement parts on danby appliances , Erin @ Jeffreys appliance service (509) 928-7176
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: inside fan on Keg Cooler needs to be replaced
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Posted on Aug 07, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Danby dkc645bls cools once, then wont kick back on
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Posted on Feb 17, 2010
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Inside fan on Keg Cooler needs to be replaced
Jul 23, 2009 | Danby DKC645BLS Compact Beverage Cooler
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Jun 30, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Danby DKC645BLS Compact Beverage Cooler Logo
80 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
