Question about Canon L120 Fax Laser Printer
My canon multifunction printer gives a 0091 error during TX error. It is only to one phone number and they are able to fax us
2 Suggested Answers
MUKHTAR
  • 2022 Answers
SOURCE: My Canon MFP4150 cannot send international faxes.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Posted on Jan 20, 2010
Sharp fault codes
Try using the speaker button in the fax mode to dial out, that way you can hear what the operator is asking for. You might need to dial a 1, or you might need to enter a long distance code. It all depends on your phone system.
Copier Collin Houston TX Copier and Imaging Expert
Aug 21, 2014 | Sharp Mx-4111n Multifunction Copier
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
Jan 20, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Multipass mp390 cannot fax
There are many things that can cause that, the error number is listed with the NG code. Could be the fax on the other end not responding, bad phone connection, improper setup like the setting for pulse and tone dialing. or using a digital phone line instead of analog.
Dec 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
How do I print a transmittal report after each fax sent?
Press the Menu button; use the right or left arrows to select device settings. Use the up or down arrows to select Fax Settings. Then TX settings.
Select TX report, then select to print a transmission report after each transmission, then select attach TX image. (This will attach the first page of the fax).
TX report Sets whether to print a transmission report after each transmission.
When Print error only or Print for each TX is selected, specify the following.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
0009: Error during TX message
Guys,
I got the same problems and then I contacted our PSTN provider and they configured the route. Now it is working fine!
Jul 18, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon L120 Fax Laser Printer Logo
274 people viewed this question
old marine
old marine
