Question about Maytag MDE308DAYW Electric Dryer
Dryer is squealing how do I get to the back of the barrel
  • Maytag Master
  • 8,220 Answers
Unplug it.dryer is squealing how do I get to the back of the - 8195eee.jpgRemove the front and then you remove the shrould. MORE HEREe78c7ef.jpg
Posted on Sep 02, 2010
I have a squeaky dryer
You have a belt that goes around the barrell and the belt has a tension pulley on a tension arm. Those pulleys go bad. It is an easy fix. It takes longer to get to the pulley than to fix it. It is a 4 minute fix, but it will take a while to take off the housing to get there.
May 08, 2015 | Frigidaire FER641FS Electric Dryer
Why is dryer squeaking,belt sprayed but still squeals.
If the belt is to lose it can slip and squeal. worn out belts do the same.
Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
Dryer squealing
Squealing on dryers is often caused by fibres accumulating around the front of the drum. Does pushing/twisting the dryer out of it's normal shape stop or change the squealing? Does it squeak if you turn it by hand?
If so unplug the machine and make sure it's cool, remove top and side covers (normally pretty easy) and give the inside a good vacuuming with a crevice tool, if you can get to the air chamber at the back of the drum that's where most of the offending fluff will be as it gets through the filter and fired into the back of the machine.
Put it back together any you're done.
Oct 03, 2011 | Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
The dryer squeals on start up and quiets after 40 seconds or so. I took it apart and the belt and pulley seem ok. How do I know if they are worn? I thought it was a problem with the felt liner at either...
Sorry to read about your problem, I hope this helps you out.
you have a drum bearing, going bad, or your belt tension pully. it stops squealing because the unit heats up and the metal expands. you can also try spraying (WD40) the belt tension pulley..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Maytag MDG9606 Dryer
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Squealing dryer.
Squealing usually refers to dry bearings. And the only bearings on a dryer that I know of, are where the shaft of the drum attaches to the back. But these seldomly give trouble. Can you tell where in the dryer it's coming from?
Dec 17, 2009 | GE Spacemaker Washer and Dryer Electric...
Maytag dyer was squealing now smells like burnt rubber
Sounds like you may have a belt slipping.Take the back off &see what the belt looks like.
Aug 28, 2009 | Whirlpool LER4634J Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Maytag MDE308DAYW Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
