I just turn off the gas and now how do I re start the airco furnace
  • 107 Answers
The gas lines will as you know have air in them. AFter trying to start several times the heater will lockout.. I would suggest turning power off to unit and turning back on to reset.. Try several times until gas finally gets to unit... did this work ?
Posted on Sep 05, 2010
The heater turns on, but does not ignite. The fan runs for about 5-7 seconds then shuts off. I am assuming the heater needs a good cleaning?
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... I hv gas furnace we turn thermosate on upstairs but still wont turn on coud turn ...
Furnace Not Starting - Clean the Flame Sensor - YouTube
? 3:15
https://www.youtube.com/watch?v=Ecd5CzJjss4
Jan 4, 2012 - Uploaded by Home Improvement Videos
If you woke up to find that your gas furnace is not starting or it's ... If this sensor gets dirty (and they almost always do over time) then your furnace will try to light, ... working, you can hear it starting, but the burners on not coming on. ... The furnace nowcomes on every time and the house is nice and cozy.
Furnace wont start. What to do before calling the repair man ...
? 10:11
https://www.youtube.com/watch?v=yJxDc90hs4g
Sep 12, 2012 - Uploaded by grayfurnaceman
Our property manager is great about sending a repairman, but the house is a mess. ... While troubleshooting my downstairs furnacethat wouldn't turn on, I turned off the ... Not sure what to do now about flame rollout switch..
Jan 05, 2016 | Heating & Cooling
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Furnace blower won't turn on
You may need to replace the sail switch. It senses the fan speed and when it connects the gas valve should open and furnace should fire up.
Dec 09, 2013 | SUBURBAN MANUFACTURING Rv Motorhome...
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
I'm looking to buy motor for an Airco Gas furnace model ACF-45, serial #DI-109. The motor is Tamper, 1/6hp, 1727rmp, type S-100336. Do you have any suggestion?
Hi, W/D here.
Make the necessary sketches, showing what color wire goes to which terminal (trust me on this, it's a really good idea). I do it whenever two or more wires are involved, and I've been known to also lable terminals with the wire color with a "Sharpie". Remove the motor and start capacitor. Take both with you to your local appliance parts supply house. They will match you up with a similar motor, and match the capacitor to the new motor. Getting the exact motor you described isn't important. Getting a good quality replacement motor with your horsepower rating, shaft size and matched capacitor is. They'll have it, and the cost will be less than running one down. I installed a replacement in a furnace last week, with the motor, capacitor and a pack of crimp-on terminals (I ran out!) costing about $109.00. Your's may be less at 1/6 hp. The one I installed was 1/3 hp, replaced a GE, and works fine.
Best regards, --W/D--
Feb 19, 2011 | Dayton Gas Furnace Heater
Combustion Chamber hot air oil furnace
it is down to cost how old is it , is it worth it over the cost of a new heater you will neede to speak with a plumber to see what is best to do with this heater as they can look at the heater and advice you .
Jan 29, 2010 | Heating & Cooling
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
