Question about Boating
Have a yamaha outboard sn/e25a 61n s oo1924 an need to know the year it was made an what model in the u.s.a. is its mate. I was told from usa yamaha that it was not made in u.s. or canada.
3 Suggested Answers
SOURCE: year model of yamaha outboard and fuel mix ratio
See linked manual!
JD
Manual
Posted on Sep 26, 2009
saailer
  • 1868 Answers
SOURCE: What year is it and how much is it worth?
Hello! Check the serial # again, The serial# 3134966 isn't a valid number...Also do you mean 220HP? Also the year of the engine should be directly below the serial #...Describe the condition in order to set the retail price...
Guru............saailer
Posted on Feb 04, 2010
How do I remove the mid section on a mercury four outboard engine
Hey Dennis,
What has happened to this engine that requires the Driveshaft housing to be removed? Please give more info/details in a reply to me. Thanks!
I need model/year/HP.. etc..etc..
https://www.marineengine.com/parts/mercury-outboard-parts/100-4-cyl/0g760300-thru-0g965520-usa/driveshaft-housing-usa-0t801000-bel-0p268000-and-up
Jun 04, 2017 | Mercury Boating
Timing specs 30hp Yamaha outboard ?
Try this site..Didn`t know what year...Cheers
http://forums.iboats.com/Yamaha-Outboards/Timing
Jan 29, 2017 | Yamaha Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
What year is my mercury outboard
What year is my Kiekhefer Mercury Outboard SN 389664, Mdl-KF-7
Jan 05, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Yamaha 50 outboard bogs at hi speed
Make sure carbs are clean,check exhaust tube isn't blocked,check resistance readings on charge coil,make sure filters are clean,no fuel leaks in fuel line,tank has open breather,fuel connector not blocked.if this doesn't solve the problem could be faulty cdi unit
Sep 25, 2013 | Clymer Marine Maintenance and Repair...
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
Boating Logo
104 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
