Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Good afternoon, my Mitsubishi model 42413 turns on, then immediately back off back again. After testing with the menu and device buttons, I get a flashing 2 - 2 code indicating a fuse is blown. I opened the set up but can only find one fuse where the power cord enters the circuitry. I take it the fuse I am looking for does not present itself as a "fuse" we are accustomed to seeing, i.e. glass tube with a filament inside. What should I look for and where?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2,2 means one of the pico fuses (see attached photo) that protects the convergence circuit is blown---This set uses 2 of the STK-394-250 convergence chips---you need to locate and replace the fuse and the chips---do not just replace fuse---it went for a reason, if just fuse replaced it will blow again and likely do other damage.
If this or the photo helped, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 02, 2010
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
When turned on mitsubishi WT-42413, it turns off itself within a second. any help?
Check you -24and + 24 on power supply and you green fuses if open fuse replace fuse and the stk394-250 good luck
Jan 16, 2011 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi rear projection HD1080p tv model # ws-48311
press in the menu and input/device buttons both in together on the TV and hold in for 6 seconds to see if the led will blink a two digit error code then let me know what the code was.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power on
From what you have said it seems like the thermal fuse of the set is down... You will have to replace it and then check if it works..Post back if you need more help..
Good Luck!
Jul 16, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi wt-42413 Power problem
Okay try to distinguish if the three blinks is 1 pause then 2 blinks or 2blinks pause 1 blink. As the set will only blink a two digit code 12 meaning no error detected and 21 meaning the set is hutdown due to xray protection.
May 13, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi wt-42413
No you have to push the buttons on the set that say menu and the button that says Input or device both in together for 8 seconds to initiate the self diagnosis feature.
Apr 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Only Blue Screen
1. Suspect the Signal PCB part # 930B923002
Aug 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
208 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
