Question about Garmin nuvi 200W GPS Receiver
My garmin keeps trying to acquire satellite and doesn't work properly. What should I do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Most likely the GPS chip in the machine has got stuck and need to be reset. Do this either by resetting the GPS itself by doing the following:
  • Turn the GPS off
  • Press and hold the lower right corner of the touch screen.
  • Turn on the GPS without releasing the touch screen.
  • When the unit asks if you want to remove all user settings, release the touch screen and choose "yes".
This will reset the unit and most likely solve the issue. The first acquiring of satellites could take a full 30 minutes, but after that the unit should work as always.
Posted on Sep 06, 2010
  • 12 Answers
SOURCE: won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Posted on Dec 09, 2007
  • 35 Answers
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Posted on Jan 21, 2008
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
  • 40 Answers
SOURCE: Garmin 680 -cannot acquire satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Posted on Jan 02, 2009
  • 6 Answers
SOURCE: Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Posted on Jan 24, 2009
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
Satellites not found garmin 755
is it getting to the satellites?
if not improve the battery level by charging properly.
Jul 06, 2009 | Garmin Nuvi 660 GPS Receiver
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Dec 05, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
559 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
