Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
D40 will not power up
I cannot get the camrea to come on at all. I have an extra battery thinking that was the problem. Nope still not power.
doodleorb@aol.com
  • rambunktor Sep 24, 2008
    My camera won't turn on, and I've tried with different batteries. Putting in a memory card does not make the light go on. I've tried the hard reset and had no luck.
    Someone mentioned broken on/off switches, is this a recognised technical fault?
    If anyone can help, it would be much appreciated
    Thanks
  • 111 Answers
When a charged battery is installed, the card access led on the back of the camera should blink once. If it doesnt, try resetting the camera with the small microswitch on the bottom of the camera body (opposite side from battery compartment). Failing those, have a Nikon shop look at it.
Posted on May 22, 2008
  • Mark Day
    Mark Day May 22, 2008
    From other posts, there have been reports of defective on/off switches.
Nikon d40 won't power up
The Nikon D40 uses the EN-EL9 7.4 Volt Li-ion Battery. You should be able to read 7.4 V DC between the (+) & (-) terminals of the battery after it has been in the charger for several hours. If it does not, it indicates a bad battery, charger or both. There should over 7.4 V DC on the terminals of the charger if there isn't, it suggests a bad charger. If the battery voltage is OK, make sure it is inserted correctly. If still having trouble, it may be related to the camera power switch or internal circuitry. This will require returning to Nikon for repair. Good luck!
Aug 20, 2013 | Nikon D40 Digital Camera
Remote Control not working
take a digital camrea or a camrea phone point the remote sensor (the bit you would aim at your player) towards the lens of the camrea and look on the camrea/phone display press buttons on the remote can you see a flashing light coming from the sensor ?? if not its due too a flat battery or faulty remote if you do then its likely too be a fault with the player
Dec 09, 2010 | Mintek MDP-1810 Portable DVD Player
THE CAMREA TURNS ON BUT MAKES A BEEPING SOUND WITH A RED FLASHING LIGHT. THE CAMREA WILL NOT ALLOW ME TO TAKE PICTURES ONLY REVIEW THEM
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Olympus FE-20 Digital Camera
Have problem with my control
to see if your remote is working obvouisly put in new fresh batteries turn on the camrea on your phone or get a digital camrea and point the infa-red sensor at the camrea and press some buttons while looking at the screen of your phone/digi cam should see a white flashing lights as you press the button if nothing then the control is dead
Sep 10, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Acer Aspire 690 still no sign of life :(
FIRST CHECK ALL THE CONNECTIONS ON YOUR MOTHERBOARD.IS IT PROPERLY CONNECTED.N ALSO CHECK UR POWER SUPPLY.THNXX
PLZ RATE THIS IF U FIND IT USEFUL.
Apr 03, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Camera does not power-up
If the battery is ok it suggests the charger unit is faulty.
If still under warranty, your supplier should exchange this free.
If out of warranty, I suggest buying a standalone battery charger to charge your battery without connecting the camera (and maybe a spare battery - always handy to carry a spare with you).
They are not very expensive.
Regards,
Mike.
Feb 23, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Images displaced, cut off at bottom & extra content at top.
flash trans. is broken i want to replace if there any matching ?
Dec 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Compaq Presario 2140 laptop won't turn on
I would first remove the battery and leave it unplugged and hold down the power button for 45 seconds. that does a system discharge of power. put the battery back in and try the power again. Write back if this does not resolve your issue.
Oct 22, 2008 | Compaq Presario Notebook
My nikon D40 says my battery is dead
For the price of a battery, I would replace it. There are plenty of good quality chipped aftermarket batteries for the D40 for only a few dollars.
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Monitor unlit
the best thing to do would be to press the 2 green dots together to do a master reset on the camera. 1st green dot would be just beside the shutter and the other would be on the left of the lcd. press and hold them both for about 10 secs
Aug 27, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
502 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
