Question about Kenmore Dryers
Kenmore gas dryer 80 series -Ignites and flame is visible for a few minutes then falmes goes out. Tries to ignite but no flame. After 15-20 minutes of cooling I try again same thing. Starts fine for a few minutes and shuts down.
  • Kenmore Master
  • 2,128 Answers
You have bad gas coils located on top of the gas valve
Posted on Sep 04, 2010
  • Sal DeAngelo Sep 05, 2010
    also if the dryer is clogged with lint this can happen,try running it with the vent line off the back of the dryer,you need to take the dryer apart,clean out the duct that the lint filter slides into,vac out the cabinet where the motor is,if you have a shop vac put it on blow and blow off the motor and the heating system,next if the vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure the outside vent is clear before you blow out the vent line,also i've found on some dryers that were loaded with lint that on the back of the thermostats located on the blower wheel housing had lint stuck to the back of the thermostats and they can't work correctly,just take out the screws,pull them out and clean the lint off them,let me know how you make out
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
My kenmore gas dryer ignites and the flame shuts off after 10 sec
The valve on the pilot may need to be replaced. The springs get worn and wont stay up. Otherwise you could replace the entire pilot unit with a kit.
Jul 20, 2009 | Kenmore 74602 Gas Dryer
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Dryers Logo
207 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
