Question about Sony Ericsson K660i Cellular Phone
When I put it on charge it charges fine but as soon as I take it off charge the battery is extremely low. whats wrong?
  • 4,102 Answers
Hi you have got bad cells in the battery and this is preventing it from holding a full charge so even though you leave it on charge it will never last long, all you need to do is get a new battery and your phone will be back to normal
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 02, 2010
Testimonial: "very helpful, thanks :) "
  • leeeaaahhh_x Sep 02, 2010
    I actually just bought a new battery.. its been working fine until now! I guess thats what I get for shopping on ebay... lucky battery 3! haha, useless excuse for a phone! :P
  • paul proctor Sep 02, 2010
    Hi i wouldnt buy and batteries off the auction site most of them are cheap imports from china and dont last more than few weeks.
    a few things that would cause the battery to drain quicker
    1. make sure you bluetooth is turned off this causes the battery to drain all the time so only turn it on whilst using it and turn it off after
    2 if you speaker is loud turn it down a bit you only need to hear the person talking so if you have it on highest settings then this will also drain the battery.
    3 if you ringer vol is on highest settings then this will cause it to go flat quicker most people dont need it on the highest setting unless they have hearing problems.
    4, now every 6 weeks let the battery go totally flat let it go that flat that it wont even light the phone up when you press the on button, then give it a full charge for about 4 hours.
    doing this prevents the build up of bad cells and this keeps your battery in best condition and will last a lot longer.
    i hope the above have been some help to you, number 4 is about the best trick to keep the battery at its best
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 | GE Cameras
I tried to jump a friends car,it didnt start so we got a new battery.on the way to get her battery my ac wasnt blowing right then battery light cam on.after fixing friends car got in my olds and it ...
clean and tighten all your battery connections and fully charge it,, when you get it charged , have it LOAD tested, you may have a dead cell in it, once you know you have a good , fully charged battery ,, test the battery posts with a meter,, you should get a reading of 13.5 to 14.5 volts, if not, your alternator isn't charging correctly,, ( note,, use extreme care when jumping another car, a single back feed into your car could fry the computer,,
Sep 05, 2011 | 2000 Oldsmobile Silhouette
15 min energizer charger cuts off after 5 seconds
Plug it into mains without battery.
Put the battery(s) into place. If batteries OK (but need charging) it will begin charging. If batteries very low it will cut off. If batteries charged it will charge only 1 - 10s.
Jun 07, 2010 | Energizer 15 Minute Battery Charger Combo...
I put my camcorder to charge, but it won't charge at all
If this is happening with your new battery, your charger is possibly defective and improperly charging. I suggest trying a new charger!! Hopefully this helps,,please rate thanks!!
Aug 05, 2009 | Video Cameras
Phone won't turn on
dear there is clear problem in your charging place that can not transfer the charge to the cell part till it remins to the bettry not move forward into the moblie..
so let the check of charging place below mobile
May 26, 2009 | Nokia 5300 Grey Cellular Phone
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
06 f150 if lights left on for under 10 min truck needs jump
your first three words...battery checks ok....??? See why its difficult to do this from my end?
Anyhow, here are a few suggestions to keep new battery OK.
If you like to sit in parking lots (or other places) with the radio on, put a small battery charger on your battery every month or so to bring it back to fully charged.
If you run the battery down by leaving anything on (key, dome light headlamps, and need a jump to start, charge the battery with charger also, as soon as you can. Reason is, your alternator is not designed to charge a battery. It's purpose is to maintain the state of charge in the battery. Though it may seem OK after a jump and drive, it will never again have a deep charge unless you put it there with a charger.
This also overworks the alternator.
So aside from keeping it clean on the outside, if you follow this rule it will be happy on the inside and give you even longer than its expected service life in return. Good luck with your car!!
Feb 12, 2009 | 2006 Ford F-150
I have a Skil 2362 7.2v drill that goes dead when charged
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Jan 19, 2009 | Bosch Skil Drill / Driver Kit
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Sony Ericsson K660i Cellular Phone Logo
89 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
