Question about Mitsubishi VS-50605 50" Rear Projection Television
125v 5a fuse keeps blowing out - Mitsubishi VS-50605 50" Rear Projection Television
  • 1153 Answers
SOURCE: Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Posted on Sep 09, 2007
likha
  • 790 Answers
SOURCE: 2 fuses blow on power up
HI
Good day sir! if you have knowledge in electronic trouble shooting, ican give an instructions to fixed this trouble!
But if you have no experience in electronic trouble shooting much better to call a qualified technician in this site near you! just type www.fixya.com then go to find repairman.
Posted on Nov 15, 2007
  • 1153 Answers
SOURCE: Blown fuse
What was the orginal problem?
Posted on Nov 25, 2007
Cybertech
  • 149 Answers
SOURCE: PRO-520HD Tv will not stay on
you may have short in convergence circuit but this is a job for experienced tech after replacing ic's need to get in to settings and and is kind of complicated
Posted on Mar 30, 2008
  • 2336 Answers
SOURCE: Where to purchase pico fuse in DFW area
Click here to find the pico fuses.
Posted on Aug 18, 2008
I'm trying to fix my Viewsonic N4825P. I have narrowed it down to the power supply since every time I replace the fuse and plug in the tv, the fuse blows. The fuses I am using are 5A 125V. Do I need t
I would suggest trying what is called a slow burn fuse of the same size, if there is something wrong with the power suppy then the fuse will continue to blow I would not recomend a higher amp fuse as this may cause other things to fry in unit.
Nov 13, 2012 | Televison & Video
Pioneer sd-643hd5 fuse issue
The fuses may not be your problem--I have fixed several of these---The large power board is on the right side as you look from the back?
Lots of these sets develop bad solder connections on that board--several sites on the internet offer to have you remove and send them the board to resolder--this set used lead free solder and after some years has problems--a few I have opened had clearly broken solder joints--I usually in this case remove the board(mark all the many plugs and make a diagram) and solder almost all of it by hand----usually fixes this kind of trouble.
I do this here for free so if this information was helpful give me a vote here....I am here to help people.
If you have any questions or need advice reply to this posting here.
SD TECH
Sep 12, 2009 | Pioneer SD-643HD5 64" Rear Projection...
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
Mar 18, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
