Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
Samsung RSH1DTMH fridge freezer. All of a sudden the fridge temperature has risen to 14 degrees and i can't get it back to the usual 3 degrees. I have switched the power off for at least 10 minutes and also pressed the fridge temp button to alter it myself. It will alter but then jumps back to 14 degrees.
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
HI THIS SHORT VIDEO MAY HELP">
Posted on Sep 16, 2010
RSH1DTMH Temp problem solved by removing shelves and fridge fan unit and de-icing to free the cooling fan. Also after power outage the display only had loer right segment flashing and unable to set temperatures, This is resolved by pressing the top left and top right buttons on the display panel for approx ten seconds, This resets the display to normal.
Posted on Mar 05, 2012
  • paulhaz
    paulhaz Mar 05, 2012
    RSH1DTMH Temp problem solved by removing shelves and fridge fan unit and de-icing to free the cooling fan. Also after power outage the display only had lower right segment flashing and unable to set temperatures, This is resolved by pressing the top left and top right buttons on the display panel for approx ten seconds, This resets the display to normal.
  • alfy Aug 18, 2012
    Thanks. Resetting the display seems to have solved the problem. Much appreciated
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Samsung RS2630H - Fridge temperature will not go below 14
The first thing to do is clean out from under and behind the refrigerator thoroughly. In over half the cases like this, I've found it's just a matter of not enough air getting to the compressor, because of dust bunnies or other things blocking the airflow. You'll need to empty it and tilt it back to clean out from under it properly. But I will be surprised if that doesn't fix your problem.
Aug 31, 2007 | Samsung RS2630SH Side by Side Refrigerator
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
My Samsung RSH1DTMH Fridge Freezer the fan started making a strange noise like either hitting some ice or a bearing gone now noise stopped but temperature gone up to 12 from three can you help please ?
We had the same problem with our Samsung RSH1 fridge freezer. We bought a kit from a company called Appliance DIY Repairs, that were recommended to us by a friend. We fitted the kit. It was an absolute doddle - and considerably cheaper than getting an enginer out to fix it.
Jun 23, 2010 | Refrigerators
Samsung RSH1DTMH fridge/freezer - Left hand side keeps freezing over in the fridge,by the deodorizer. What causes this?? Please help - Ty
Usually, there is an issue with one of the following:
* electronic temperature control located in fresh food compartment
* defrost thermostat and/or heater(s) located in freezer compartment
Contact an appliance service company.
Feb 16, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung fridge freezer model number srs615dp. The temperature displays -16 and 3 degrees. After approx 10 hours the display flashes. Turn off the power and on again and it displays 4 and 14 degrees and...
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Jul 04, 2008 | Frigidaire FRT18B4A Top Freezer...
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
2,501 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
