Question about Arrow & Professional Cordless Staple Gun
Craftsman model 836.272350 cordless stapler. Quit working. recharged battery and installed battery nothing happened. removed outside cover and replaced it (7 screws) after inspecting for obvious problems. Stapler then fired once. Removed cover again and replaced it and Stapler fired once. I can't see any really worn out parts. What is broke and are there parts available. It has been a very reliable stapler until now. Ray
  • 132 Answers
SOURCE: stapler repair
Sydney 02 8004 2111 you might have to post to sydney for service
Posted on Nov 15, 2008
  • 9 Answers
SOURCE: My friend let me borrow
Most arrow staplers have slide levers along the sides toward the front. Pull back on these and it should pop open. Some however load from the rear of the stapler. You push in and down on a square metal piece and it will unlock and than you pull it out toward you. slide in a rack of staples, put it in, relock and ready to go. If you put in too many staples it wont go all the way in to re lock.
Posted on Dec 02, 2008
SOURCE: installing nail brad in a stapler
I have the same problem and the silly thing is I have used it. Ridiculous that you can't find a manual on it. Well, I have solved it!!!!
our problem is we open the stapler and stare straight down into the cavity. But if you angle it, you can see that there are grooves along the side which the head of the brads would hang and slide along.
1. on one side of the stapler it will say "load brad this side"
2. open the chamber and place the stapler on its side with the aforementioned side down
3 place your strand of brads in the appropriate groove and close the chamber
4 start shooting
pklew52@gmail.com
Posted on Jan 06, 2009
  • 40 Answers
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
What size staples do the 9.6v craftsman cordless staplers use?
Your staple requirements will be noted on the gun shoe ( staple magazine). Usually guns of this size take T-50 staples. Good luck with your projects
Apr 11, 2011 | Tools & Hardware - Others
In December 2009 I had a new garage door opener installed. I have 2 remotes for this unit. One just quit working. How did I fix it? It is a Sears model - Craftman 315 #139.18191. It is not the battery...
I don't trust batteries even when they are new. Try taking the battery out of the remote that is working and install it in the remote that isn't. If that doesn't work you need to purchase a new remote.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Stapler (swingline 211xx) has jammed. It is electric. When I plug it in it make a very loud noise like it's trying to staple but nothing happens. When i press the release button on the top the stapler tray...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
May 20, 2010 | Office Equipment & Supplies
MY SEARS 9.6 VOLT NARROW CROWN STAPLER WILL FIRE ONE TIME OR TWO, THEN QUIT. IF I PULL THE BATTERY BACK FROM ITS LOCKED POSITION ABOUT 1/4" IT WILL FIRE EVERY TIME. GOT ANY IDEAS? I LIKE THIS STAPLER...
The terminals on the battery or on the stapler must be damaged (bent or corroded). It's probably the stapler if the battery charges fine. Does it do the same thing with another battery, or just one? Assuming it's the stapler, and you don't want to mess around with the terminals you could tape a spacer on the stapler to keep the battery 1/4 inch out. You would probably have to tape the battery in place though. If the problem is corroded terminals, I have found that a little wire brush attachment in a Dremel works great. Not a brush like a disc, but a brush that looks like the kind used for paint stenciling.
May 21, 2010 | Arrow & Professional Cordless Staple Gun
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My GE Dect 6.0 model 28821FE2-A quit ringing and Do Not Disturb is not "On" and volume level is 5.
Sounds like you might want to remove the battery for a day to erase the memory and change the phone settings back to the factory settings.
Open up the back cover of the handset, remove the rechargeable battery and leave it disconnected for a full day. Do the same thing for the base unit, they sometimes have a 9volt battery in the base unit.
Hopefully after the phone if reset to factory settings the ringer will work again.
NOTE. you will lose all your speed dials and other custom programming when you do this procedure.
Good luck with the repair.
Jan 28, 2010 | GE 25932 Cordless Phone
Wireless just stopped working. Changed batteries,
The behavior described indicates weak/dead batteries. Logitech brags about the battery life on this model, but in reality battery life varys dramatically between invidual units. I've seen one that would not operate at all on Ni-Cad rechargable batteries (only 1.2 volts even at full charge). If you must use rechargeables, stick with NiMH (metal hydride). Better yet, use long life lithium.
Also, make sure the "Nano" receiver isn't sitting in the storage bin. This is one of two ways to power off the mouse. The other is the 'Clip N Go' dock.
Sep 24, 2009 | Logitech Cordless Mouse
Craftsman cordless drill won't work even after charging battery.
Try working the switches Low/High, Forward/Reverse. Sometimes, the battrey can hang up a bit in the charger, resulting in a low, or no charge. Try a different battery, or recharge your existing battery, making sure that it is firmly seated in the charger.
Regards, --W/D--
Jul 18, 2009 | Craftsman Drills
No dial tone on
perhaps that is why it quit working no electronic equipment I ever had liked water . just buy a different phone for use there
Oct 28, 2017 | Uniden Cordless Phone
Arrow & Professional Cordless Staple Gun  Logo
471 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
