Question about Chaintech SK8T800 Motherboard
Can't get SATA hard drive to work
The motherboard won't detect my new sata wd hard drive.
  • 58 Answers
Make sure the jumper switches are correct on the hard drive i:e master or slave,perhaps computer select (cs)
Posted on May 10, 2008
3rd SATA Hard drive can't detecte.
is the sata port activated in bios?
Feb 22, 2013 | Computers & Internet
Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.
Now boot into Windows and click control panel.
Double click Administrative tools and double click Computer Management.
Left on screen: Select Disk Management under the heading, storage.
Here is where the hard drive should be detected. If not present click action, followed by refresh.
Now select your new drive and format it using NTFS.
Take care!
damnor01
Jun 07, 2012 | Gigabyte GA-8I915ME-G Motherboard
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Nov 19, 2009 | Computers & Internet
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
Problem with SATA WD Caviar SE WD2500AAJS hard drive model
Maybe the sata controller on your motherboard is disabled. Try searching for the settings of your sata controller on the bios and enable it.
Jan 02, 2008 | Maxtor Hard Drive
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Chaintech SK8T800 Motherboard Logo
123 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
