Question about OKI B4525 MFP All-In-One Laser Printer
My Okidata 4545 MFP on the LCD displays 3 doc. to send. They never are sent. They just sit in there and slow down the machine. How can I erase these out of the system?
Keystrokes to clear error are:
Down (down arrow)
8
Posted on Oct 25, 2010
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
How to reset drum error on oki c5550n mfp
Hi Eric, what is the exact drum error you have? CMY or K?
Aug 02, 2014 | Oki Electric Industry Okidata C5550n MFP...
Fatal error 708
Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
Dec 14, 2010 | OKI C3530N Color MFP Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
Display not reading properly
Try this first
Open up the doc feeder
unplug the power cord
hold down the pointed switch behind the small glass strip while plugging the power cord in
close the doc feeder
scroll down to SHIPMENT SET
press SET
press 2 for no
wait for machine to intialize.
if this doesn't work you have a bad LCD display.
Jun 22, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Okidata C7500 Little part broke on the duplex tray. Won't Duplex
You will probably save money by purchasing a new duplexing unit online.
Jun 03, 2009 | Office Equipment & Supplies
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Aug 06, 2008 | HP LaserJet M3027x MFP Printer
Lexmark x644e LCD Display Upside Down(Inverted)
Hello there,
I've seen this before. The X64X series with this inverted display seems to work fine (printing,scanning,faxing..) the reason for this is still unknown. But I've got it fixed twice by resetting the NVRAM on this MFP. If you are unsure of how to reset NVRAM, please follow the instructions below:
1.Power off the MFP
2. Hold down the 6, 7 and 8 buttons down and turn the MFP On.
3. Please hold down the buttons till it reads resetting factory defaults and then release the buttons. The MFP should now come back to ready status.
Please check out if this solves the issue, If not the machine would need a hardware service.
Merry Christmas!
Dec 18, 2007 | Lexmark T632 Laser Printer
OKI B4525 MFP All-In-One Laser Printer Logo
73 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
