Question about Ricoh Aficio 450 Copier
Paper jam in 2nd feed mae z fold from tray 1 and 2
  • Ricoh Expert
  • 1,326 Answers
If the paper is "Z' folding at the reg. roller you may need a new reg. clutch or you may clean it. If it "Z" folding in the fuser, you may have a pick off claw that is in the wrong postion. Good Luck
Posted on Sep 03, 2010
Oki MC361 keeps jamming when paper feeds from printer tray or manual feed.
Take out both the drum tray and the transfer belt. Reseat the transfer belt and make sure both clips at the sides are locked down. Reseat the drum tray and checked it is firmly located. Re-try your prints. If it still fails, take the paper tray out and check for a paper fragment in the paper feed path.
Oct 07, 2017 | OKI Office Equipment & Supplies
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
When printing, the paper will start to feed and then pulls to the left, wads up and jams. This happens with both Tray 1 and Tray 2.
Hi You have a small paper jam in the front of your machine,
remove all the trays and the toners have a look under the machine in the place of tray 2 you will see a slot that the paper should feed in to. Fold a sheet of A4 in 1/2 lengthways push it in to the slot and with luck it will come out in the machine, holding on to both ends work the paper along the slot moving it up and down until your paper jam come out
if this is useful please rate me.
Mar 08, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
145 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
