Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I've lost the plastic lamp cover and have no idea where I can buy a replacement...
    President:
  • 1,284 Answers
You will need part number X-2048-503-3 for the lamp door and can purchase it at www.partstore.com
Posted on Sep 02, 2010
Changing the brake light lamp/bulb
the plastic posts are guides /support they just slide into place attached to lens just slide/pull the lens off
Jun 18, 2017 | 1995 Toyota Corolla
Toshiba 56mx195 tv will not turn on without lamp cover door
First, you need to fix the power supply problem, then take care of the door
Oct 11, 2012 | Toshiba 56MX195 56" SDTV
How to fix gx610 dim screen
It appears from the description that the back lamp is going out on you. Replace the lamp and you will solve this matter. It is located inside the monitor cage you have to undo the screws hidden by rubber round covers remove those and you can gently pop the plastic piece off of the screen exposing the Screen and Lamp area get a proper replacement lamp and install it you can get video tutorials on Youtube to do this. Just type in the search area how to replace a back lamp on a laptop it will give you some idea. Here is example photo below it may not be the exact as yours but it gives you the idea what your looking for.....John
Apr 24, 2012 | MSI GX610-Neo Notebook
I was watching tv this morning and my set made a loud popping sound and the screen turned black. A red light appeared which read lamp and there was a burning smell. I unplugged the tv waited for a few...
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Jun 08, 2011 | Mitsubishi WD-57734 57" HDTV
How to replace bulb on sony kdf-55000
there are 2 hand screws on the back of tv, both sides, loosen them, them remove the lower front plastic cover, it is tight, you will need to pull on it hard after you loosen the screws, when you remove the front cover you will see the lamp access door, one hand screw removes it. 2 allen screws remove the lamp, if you buy a sony lamp, it will come with the allen wrench. if the glass is busted on your lamp it is definately bad, if it's not busted, you might have another problem.
Sep 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
How do I replace the Projection Bulb on a Sony KDF-E55A20 and what where do I get the replacement bulb the cheapest....I have pulled the module...
It is my recommendation that you replace it with a Sony Lamp Assy. Do not go cheap buying a generic or just the lamp only. They have been known to be unreliable and the wattage to be wrong causing the surrounding plastic to melt. Sony will not be responsible for this if it happens. If you have pulled the Lamp Assy. out, just put the new Lamp Assy
in it's place. Be sure to remount the lamp cover properly. Remount the outer cover and you are good to go.
You can contact Sony at 1800-222-SONY
for the lamp.
Hope this helps,
Skyassoc
Jun 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Replacing the light lamp for the 60V500
Hi, pull off the plastic cover just below the bottom of the screen, remove the phillips screw from the lamp door cover then the screws from the lamp housing and pull straight out, do not touch the glass portion of the lamp with your fingers, the oil from your skin will shorten the life of the lamp,
when installing new lamp push into tunnel just far enough that it touches end of tunnel then snug with screws. DO NOT push in hard on lamp, re-install lamp door and front plastic cover and enjoy,
good luck, video tek
Feb 07, 2009 | Hitachi 60V500 60" Rear Projection...
How and where do you install a replacement lamp XL2100U?
You need to replace the lamp which is located in the front under the plastic cover. The plastic cover extends the length or width of the TV. The cover can be kind of tricky to take off, but it is just held in by pop-in type rivets that snap in like a male into a female hole along with removing the 2 large screws on the back side on each left and right side. You can't miss these two larger screws. There are two other smaller phillps screws there, but you should not have to remove these. After you remove the large screws only the front pops off and it may feel like you are going to break the plastic front cover, but it does pop off and pull straight out. The lamp will be visible right in the front and is held in by two screws and after removing the screws the entire light assembly slides right out which is plugged into a socket. You can buy just the bulb or for a few dollars more the entire plastic box assembly with the bulb already in it. Replacing it should only take about 10 minutes. Hope this helps.
Jan 08, 2009 | Sony XL-2100U Projector Lamp for...
The tv will not turn on makes a noise and the green light will go to red and flash 7 times, what could be the problem?
It is the projection lamp or bulb. I had the same problems. You need to replace the lamp which is located in the front under the cover. The plastic cover extends the length or width of the TV. The cover can be kind of tricky to take off, but it is just held in by pop-in type rivets that snap in like a male into a female hole along with removing the 2 large screws on the back side on each left and right side. After you remove the screws the front pops off and it may feel like you are going to break the plastic front cover, but it does pop off and pull straight out. The lamp will be visible right in the front and is held in by two screws and after removing the screws the entire light assembly slides right out which is plugged into a socket. You can buy just the bulb or for a few dollars more the entire plastic box assembly with the bulb already in it. Hope this helps.
Dec 06, 2008 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
