Question about Microwave Ovens
Need microwave reset button - Microwave Ovens
What if you have a problem with the door? and the power won't come back on? My microwave has a safety latch on the door that won't let the power be on when the door is open. I tried to force the door shut accidentally (barely) and now it won't power back on? any ideas? Post Solution
Posted on Jan 03, 2010
I need to reset my microwave.
On the display it says RESET.
None of the botton respond.
Thanks
Posted on May 20, 2008
    Genius:
  • 1,554 Answers
Most do not have one , if they blow then the thermal fuse is likely out , google bullet thermal fuse to see what it looks like
http://www.progresstool.com/misc_images/G4_thermal-fuse.jpg
if not that then this fuse is bad
http://www.apwapplianceparts.com/Products/253466.jpg
Posted on May 12, 2008
Reset emerson microwave
There is no reset button. You will need a control board.
Dec 13, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Lg microwave reset button?
press start button twice it sounds as if it is still in child lock mode
Mar 27, 2014 | Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
    HELLO.
    TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
    4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
    5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
    Thanks.
    Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Is there a reset button anywhere on this model microwave
    No, but if you need t reset it just unplug it for an hour. Then you will be back to factory settings
    Jan 03, 2011 | Dacor PCOR30 Convection/Microwave Oven
    Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
    Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
    Nov 29, 2010 | Samsung Microwave Ovens
    No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
    Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
    Oct 09, 2010 | Viking DMOR205SS Microwave Oven
    Microwave Ovens Logo
    1,432 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
