Question about QuarkXPress 6.1
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Posted on Nov 22, 2012
  • Ettore Nov 22, 2012
  • angela schwab Dec 06, 2012
    Hi! Was glad to find your comment BUT: it does not work to proceed as you recommended! Are you referring to a 32bit version or 64bit versionof Windows 7 PC setup? I am on a 64 bit machine....Angela
3 Suggested Answers
  • 10406 Answers
SOURCE: How can I install my Quark 7 on my new Windows 7?
Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
Posted on May 29, 2010
  • 108 Answers
SOURCE: save quark 7 as quark 6
Navigate to File>.Export layout as project>>Choose version 6 and Export the document
Posted on Jun 30, 2008
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
Error 1720 comes while installing a driver
here's a little information that I'll need regarding this issue. 1. What operating system (XP, Vista, Windows 7, Linux, Debian, Unix, Ubuntu, etc.) 2. What version of the operating system (Windows XP Service Pack 2 Pro Corporate edition 32Bit or 64 bit, etc.) 3. What driver you're trying to install 4. The filename of and a link to that driver. 5. How far into the installation process you get that error. Thanks, and I'll be awaiting your response :) Dracconus
Jan 08, 2011 | Computers & Internet
Can you run quark 4.1 under windows 7
Please! I am using Quark 4.1 on Windows 7 64 bit just as I did on 98, XP and Vista. Without a floppy, I had to copy the installed Quark directory to newer platforms then drag out a shortcut to the desktop. I just published some work to embellish in Acrobat 10. The installer doesn't work; Quark does! I expect it will work in Windows 8 if the MS programmers don't screw with procedures that work fine now.
Oct 04, 2010 | QuarkXPress 4.1 for mac
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
May 29, 2010 | QuarkXPress
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
6.52 KERN_PROTECTION_FAILURE
Please let me know when exactly does QuarkXPress crashes
May 28, 2008 | QuarkXPress
Quark 6.5 Error code -39 in a Mac platform
in this case try creating a preferences folder under the HDD>>Applications>>quarkXPress 6.x folder and then check the results.
if it still continues then try to downsave the document to version 5 by doing a file>>save as and changing the version to 5 from there
Feb 05, 2008 | QuarkXPress
Save quark 7 as quark 6
Jan 11, 2008 | Adobe Photoshop 7.0 for PC
QuarkXPress 6.1 Logo
1,664 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
