Question about Zebra Printer 140-751-00000
My Zebra TLP 2844 printer gives me a no gap detected msg. and when I run the auto calibration sequence It prints the information but doesnt go out of Dump.
    Scholar:
  • 97 Answers
After calibration and printing the config, the printer will stay in Dump until you press the feed key again.
Hope that helps !
Posted on Sep 02, 2010
No gap detected
This could be caused by a couple of issues:
  • Dirty sensor (use compressed air and blow out printer)
  • Wrong media (using labels with black bars obscuring the gap and making it non-readable by sensor)
  • Wrong label format for size of labels used (make sure label size matches the template size)
Zebra printer no gap detected
Dec 12, 2012 | Zebra Eltron TLP 2742 Thermal Label...
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
Label for zebra tlp 28844-z with 2 columns not aligned
I'm not sure what you mean here but I'm guessing that you mean the labels are not advancing properly meaning the print is not aligned vertically on the labels. If that is the case, two possibilities:
1. The printer just did not get a good calibration on the printer. You can force a calibration by turning off the printer, pressing and holding on the FEED key while turning the printer on. Keep pressing until the status light flashes once, then let go of the FEED key. The printer will calibrate for the label size.
2. If the calibration sequence does not correct the issue, then it's possible that the gap (horziontal) between the labels just happens to be over the media sensor which is located in the middle of the 4" print width area. If that is true then the labels will never calibrate.
Hope that helps !
Apr 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Cannot print
The printer doesn't understnd the label. So it just reads and drop. The label has to be in ZPL (or I read somewhere PCL) language and then it will work
Nov 26, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Printer 140-751-00000 Logo
1,274 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
