Question about Sun Fire V20z Server
I have a Sun V20z that have an on board video card. The problem I can't get any video output to my monitor whenever I power the server up. I have tried to install a PCI video card and still get the same results. This is a new server. Can someone help me.
2 Suggested Answers
  • 1082 Answers
SOURCE: how to get 48V output. I do not have Sun 480
One place offer DC power 6V to 600v http://www.us.tdk-lambda.com/hp/default_lvgoog.asp?gclid=COGvyYGd96UCFcjsKgodqA0ZpA
2nd place http://www.matsusada.com/dc/ You may understand offerings better than I.
Most promising based on your need http://www.powersupplydepot.com/pssearch.asp?searchtype1=1&search1=48&action=Search
Hope you find what you need.
Posted on Dec 19, 2010
No display on screen
Have you tired a different monitor/video card combination? Are there more than one output on your video card?
Dec 01, 2013 | IBM System X3550 Server
Cannot Display From Monitor
How long have you waited for it to boot? I know some servers take forever before they send a signal to the monitor. However, if you're get the monitor test screen or "no signal" screen, this usually is a sign that the monitor is not getting any signal from the server, indicating a bad cable or loose connection or the like (though not always if it's still booting). Have you looked in the server cabinet to make sure nothing is broke on the on-board connection or something? Is the DVI port you mentioned on the external PCI card? What does it plug into? I'm guessing you've checked for any installed video cards. Is there another port on the front or anything under a panel?
Nov 27, 2013 | Sun Fire V40z Server
Network driver download
sunfire v20z linux broadcom driverAccording to the following PDF: http://docs.oracle.com/cd/E19121-01/sf.v20z/817-7183-12/817-7183-12.pdf
, a .zip file containing Windows drivers, including a Broadcom Device driver is located at http://www.sun.com/servers/entry/v20z/downloads.html
For Linux and other OS drivers, you need to specify the version you're running, or add it to these Google search parameters:
sun fire v20z linux broadcom driver
(Broadcom came from the available Windows drivers. It's possible that another NIC device is installed.)
Oct 29, 2013 | Sun Fire V20z Server
Server not booting by usb cdrom
work according to the below mentioned web page.
http://docs.oracle.com/cd/E19121-01/sf.v20z/817-5248-21/chapter2.html#0_48457
Apr 17, 2012 | Sun Fire V40z Server
I have a HP Proliant ML110 G3 server that will not produce a video display output. I'm plugged into the onboard graghics slot. There are two slots for add on graghics cards, 1 - PCI-E x4 and 1 - PCI-E x16,...
Do you have any other PCI cards connected to the server board? If so, make sure they are seated fully in the slot. If they are, try removing all of them and try your server again. A lot of time bad PCI or faulty seated PCI cards will cause your system not to display an image. If you remove the cards and still no video, you may have a bad video port - try a known good PCI video card for testing. If this does not work, you will need a new server board.
Good Luck
C2Solutions
Jan 05, 2010 | HP ProLiant ML110 G3 Server
There are three servers (2 G5s and 1 G4) these servers share a single monitor but i don't use any kvm switch.. I manually switch the connection of the monitor to access the three servers. i use G4 most of...
Do you try disabling Screensaver feature on those two servers...might that be causing display prob, if you try pressing any key or it would show screen
But still if it is not working, Check Power saving feature for these two Server, turn off featue to turn off display and harddisk if computer is standy by for......mins
Hope it resolve issue, Best of Luck
Oct 09, 2009 | HP ProLiant DL360 G5 (457922-001) Server
Hello, I have a SUn Enterprise 420 server which dose not have a video card nor are the seral consoles working. Is there a way to reset the console? S.
Dear,
Which console your are using. 25pin port or RSC PCI card port. If its 25pin port, no way to reset other than power off and poweron but, in case of RSC card, you do a resetrsc from OS also,
Sep 29, 2009 | Sun Enterprise 420 (RA33-ULD2-9S-002EJ)...
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
I have a BENQ JoyBook Lite U101. For serveral days I had my monitor output connected to a HP L1706 monitor. Yesterday I tried to connect my video output in our boardroom - however the output from the...
It sounds like the video card could not handle the monitor in the board room - As it is unless you have a graphics based laptop you rarely get a high quality video card built into your laptop.
Causes aside boot your computer in safe mode - This is done by tapping F8 several times during startup
A menu should pop up - select boot in safe mode
A long list of text will pass in front of the monitor - Do not fret this is just Windows telling you what it is loading.
Once at your desktop you should be able to see everything clearly
Right click on your desktop
Goto Properties
Settings
Drag the Screen Resolution down to something more appropriate e.g. 1024 x 768
Jan 07, 2009 | BenQ Joybook 5000 Notebook
Sun Fire V20z Server Logo
43 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
