Question about True 23 cu. ft. / 651 liter Commercial Freezer T-23F
WIREING DIAGRAM MODEL T 23F MODEL T 49 - True 23 cu. ft. / 651 liter Commercial Freezer T-23F
2 Suggested Answers
  • 1169 Answers
SOURCE: t-23f not freezing
Depends on how technical you want to get. Generally, measure the ambient temp of air entering the condenser coil. Add 30 degrees to that temp and convert to psi using a P/T chart. This will get you to a starting point.Remember, charging a "Hot" box takes time. Don't over charge.
Posted on Nov 20, 2009
Compressor not working
REPLACING TRUE AIR FREEZER COMPRESSOR
Feb 10, 2014 | True 23 cu. ft. / 651 liter Commercial...
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
True freezer model t -23f need wiring diagram
There is a safety cutout on the evaporator that sometimes goes open circuit, stopping the heater coming on in defrost.If the compressor will not turn off, check the condenser is clean.and the fan working. next check the thermostat hasn't broken. Lastly, check the defrost timer.
Dec 27, 2012 | True Freezers
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
I have a True T 23f freezer that I know needs a new defrost timer. My problem is finding the right one. The only numbers I can see on the timer are 8141-00B and 345-00. I can also see it's marked 2hp...
That 8141-00B is a Paragon timer model number. If you get the identical one you can just mark the numbers down and be sure to wire in the new one the same way.
Nov 11, 2010 | True 23 cu. ft. / 651 liter Commercial...
Need wiring diagram for GE model CA15DRN upright freezer-compressor relay busted & not sure which wires go to which terminal on compressor.
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Nov 24, 2009 | Freezers
T-23f not freezing
Oct 27, 2009 | True Freezers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
True 23 cu. ft. / 651 liter Commercial Freezer T-23F Logo
334 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
