Question about Dewalt DW744S 10" Portable Table Saw with Stand
Hi, i need a wiring diagram for a draper 10" table saw, for the stop start switch
rowdy45176
  • 2176 Answers
SOURCE: makita table saw switch wiring
K, from what I can remember there is nothing special about the switch, however the brake works off the armature and brushes and dirty or worn brushes will affect it. I just looked at a breakdown and there is no wiring schematic on it and I did not see any electronic module for the break. You can take the brushes out (unplug tool first) and blow the area out with compressed air. Look at the brush spring for discoloration and condition and length of brush. Makita does have a good website and also a toll free number for tech support. Their site is Makitatools.com and click on the table products and then type in your saw number. Let me know if you still have a problem and I will contact a local Makita center to get more info. Good luck
Posted on Jan 08, 2009
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: the saw has stopped I know the circut it is
NO reset or circuit. You can try and unplug tool and blowing into all the exposed areas of the bottom of the saw. WEAR safety goggles. Then what I would do is check the brushes and if you have a volt ohms meter check the continuity to the brush tubes. Start at the cord looking for a break in wiring and go from there. Let me know if you need more help, but I am going to thing brushes or switch
Posted on Jun 27, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
My craftsman 10" table saw will not start. i flip the switch and recently it would "ping"...blade would spin briefly then stop. I could find "the spot" when turning on the switch to get it started but it...
No, it is more likely the motor. To check it tho, bypass the switch and see if it kicks right in when direct wired. That way you kno if it is the switch or the motor. J.
Jun 28, 2010 | Skil 10" Table Saw
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Mar 28, 2009 | Saws
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
On/off switch table saw
Nov 02, 2008 | Saws
Dewalt DW744S 10" Portable Table Saw with Stand Logo
60 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
