Question about HP Color LaserJet 2600n Printer
Roller film is torn and tattered on edges is there a way to buy a replacement for this part? lf so how much?
    Problem Solver:
  • 17 Answers
We could actually get the part for you. It is recommended that a technician install it. Call us at 262-993-1551. We offer free shipping on all orders.
Posted on Sep 02, 2010
How to clear error 6000 canon410
Line Feed error or Error Code 6000
Condition: An error occurred in the LF encoder signal.
Problems and Solutions:
  • Smearing or scratches on the LF / EJ slit film
    - clean the LF / EJ slit film.
  • Foreign material or paper debris in the LF drive;
    - remove foreign material.
  • If other solution fail, replace one off the following
    - LF / EJ slit film
    - LF / EJ timing sensor unit
    - Paper feed roller unit
    - Logic board
    - Paper feed motor
Aug 03, 2015 | Canon Pixma MX410 All-In-One Printer
How to i solve problem on E000007-0000 on cannon IR 3025N
The fuser assembly upper roller is actually a thin film. The fixing film is probably torn and needs to be replaced. Very common problem on that model.
Nov 11, 2014 | Office Equipment & Supplies
Print smears on right edge of paper only
It is possible that the fuser film is damaged. The fuser film covers the heating element. Open the back panel, and examine the area where the paper exits. The grey film should cover the same area as the lower black roller. If not, you will either need to replace the fuser or obtain a replacement fuser film and install it. Is the printer noisier than it used to be? The fuser bushings on these printers are notorious for wearing out and causing the film to fail. If the bushings are worn then likely a replacement fuser will be the solution for you.
May 22, 2014 | HP LaserJet P3005n Printer
Problem persist e000007-0000 in ir 2420
fixing film error. You need to replace the fixing film. It is probably torn up. Replace the pressure roller while you are at it or else you will be doing it again
Apr 08, 2013 | Canon imageRUNNER 6020 Copier
Error fuser unit hl-5350Dn
The fuser unit is located at the rear side of the printer.
Fuser unit error indicates one/more of the following.
1. The fuser roller/film life is over. Replace with new one
2. The fuser film is torn. Replace with new one.
3. Fuser heater is burnt. Replace the heater.
4. Fuser thermal sensor is open. Replace it.
sonsunny
Jun 28, 2011 | Brother HL 5250DN Laser Printer
Service error 6000
error code 6000
Condition:an error occurred in the lf encoder signal
problem and solutions:
-clean the LF/EJ **** film. -remove foriegn material. -if other solution fail,replace the following *lf/ej **** film *lf/ej timing sensor unit *paper feed roller unit *logic board *paper feed motor
May 25, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
How do I repair the seam of the walking belt? There is about a 5" wide seam on the walking belt and one end has come undone (about a 1/2 inch. It catches each revolution & I'm afraid that it is going...
Be extremely careful when trying to trim a belt. Understand that many hazards exist when performing these steps that can result in serious injury. If you have any question whether you can perform these steps or not, please call a professional and do NOT attempt this repair.
There are two methods that can be used to trim a walking belt when it has developed a tattered edge:
1) Remove the belt from the treadmill for trimming.
a) All walking belts are cut at some point during their life, whether in manufacturing or later during service, so this will not compromise the integrity of the belt as long as you cut a straight line and do not leave a rough edge.
b) Remove the walking belt from the treadmill, lay the belt flat and even on the ground, and measure and equal distance on each end of the belt and mark the belt for cutting on each end of the belt. Cut no more than necessary to restore a smooth edge.
c) Use a piece of flat steel or other metal object that is straight and long enough and connect the two markings on the belt with the metal object.
d) Using a new razor knife, box knife, or similar instrument, cut the belt along the steel object. If the knife has a new edge, you should cut through the belt in one or two passes of the knife.
e) Check the belt for a smooth edge and reinstall the belt.
2) Cut the belt while it is mounted on the treadmill. This method should only be considered by those who are familiar with treadmills and very good with tools. This can be a dangerous process.
a) Track or center the belt off center to the opposite side of the tattered edge (i.e.- if the belt is tattered on the right side, track the belt off centered to the left side by about 1/2 to 3/4").
b) Operate the treadmill at a very slow speed. Usually 1.0 or 1.5 MPH will be sufficient.
c) Using both hands, line a new razor knife up on the tattered side of the belt. Make sure to cut no more than necessary to make a smooth edge.
d) With the belt moving and using both hands, lift the knife up and contact the belt making sure to hold the knife steady and keeping your hands and clothing as free from the moving roller as possible. You will not damage the roller to the point where it will hurt the operation of the treadmill.
e) Do not lower the knife until you see the belt separate from the tattered edge. Once this happens, turn the treadmill off, unplug the treadmill, and cut the tattered strip off the treadmill.
f) Track or center the belt and operate normally.
Feb 13, 2010 | Proform 730 Folding Treadmill Model...
The printer wrinkles the paper
look like you have a cracked fuser roller problem. To see it, visually observe the section where the paper exits from the printer. You will noticed a grey colored long roller riding on top of another long orange colored roller. Its usually the grey colored roller whereby certain section of the roller foil/film have been torn off and it need to be replaced.
Best Rgds
Mar 05, 2009 | HP LaserJet 1010 Printer
HP Color LaserJet 2600n Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
