Question about Envision EN-985e Monitor
Power supply I just bought a new power supply and installed it. The computer turns on just fine, but the monitor doesn't register anything. I checked the connections to the tower and they are fine. The monitor is plugged in and everything. Don't know what's wrong.
  • 558 Answers
Did you push the power button on the monitor did it glow green? or yellow?
Posted on May 10, 2008
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
My desktop computer will display anything when turned on, and the fan and hardrive both make a loud constant noise.
Maybe you need a larger power supply depending on if you might have added more hardware such as a graphics card, or an extra monitor to your system. This sometimes results in an inefficient supply of power, making your fan to your power supply work harder, thus making noise.
Nov 19, 2012 | Gateway Computers & Internet
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
The PC is dead, no fans run or anything. It will not power up so I bought a new power supply and installed it but still the same issue? It does have 120 vac power into the power supply.
maybe your CPU is busted.try to replaced a new processor and test it.or double check the setting of the power on *********** board switch,maybe you inserted wrong.
Jul 11, 2011 | Computers & Internet
The monitor is not registering that it's hooked up to a computer. It turns on, but the power light just blinks like it's in sleep mode or not connected to anything. I tried hooking it up to two different...
When its hook up to the computer, turn on both monitor and computer.
While the monitor is turn on, disconnect the vga cable. Will this display a No Signal error?
If yes, then a problem with the mainboard of the monitor, buy a new monitor.
If no, problem with the power supply section of the monitor. Replace the leaking and blown capacitors with same value.
Feb 11, 2011 | Samsung 932BW Monitor
Monitor randomly turned itself off.. now won't turn on
The problem is with the owner, useless piece of ****.
Jul 14, 2009 | Computers & Internet
HP W1907 Monitor
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Jan 03, 2009 | HP w1907 LCD Monitor
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
Computers & Internet Logo
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
