Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune frontload.. won't do anything when i press any button. there are times that it will start and then stop before the spin cylcle, mostly randomly , continually trying to start it.... ideas?
  • 2,272 Answers
Is it filling with water.If not then the fill valve needs to be checked. But if the washer is filling with water properly and after that it stops before spin cycle takes place and also not draining then:---- Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, Get the drain pump cleaned.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
Maytag® Neptune® stop mid-cycle?
turn the control dial to the cycle you want, make sure the door is closed and firmly push the START/STOP button.
There may be a pause or a soaking period in the cycle you've selected. Wait for a few minutes and see if your machine restarts.
If all checks out ok but still the same problem then its problem of control board in your washing machine.It has to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 02, 2010
Neptune dryer not starting
Yes, I recommend you type in "Sears Parts Direct" to your computer search engine.
Put in your model number in the box, and you will see schematics that will answer your questions.
God bless your efforts.
Feb 26, 2016 | Maytag Dryers
My maytag neptune front load washer will not spin this has happened before and I called service they held down some button where the start wash etc are on on top of the washer. It washed the load but when...
Check whether water is fully drained. Since the motor worked during wash motor is not faulty.
Check relay that poers the motor during spin mode. May be micro controller fault posiible.
Mar 31, 2010 | Maytag Neptune MAH6500A Front Load Washer
Our maytag neptune frontloader won't start
CHECK PLUG FUSE IF OK CHECK WIRE FOR ANY BREAKS IF NONE THEN IT MAY BE THE ON /OF SWITCH IS FAULTY.
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
