FTER SHREDDING A CREDIT CARD IN MY PS-712CDB SHREADER I CANNOT GET IT TO SAHREAD ANYTHING AGAING
    Problem Solver:
  • 10 Answers
There is usually a "safety" wire that triggers when you put paper in to be shredded. This may have been broken when the thicker card went through. Look closely at the engaged teeth to see if you can see a safety wire and a way to realigh it. Another possibility is that a part of the card has jammed the engaged teeth - try to unwedge it, being careful not to shred your fingers
Posted on Sep 02, 2010
Shredder is making a loud noise when attempting to shred a document.
The shredding mechanism could be clogged to the max or someone tried to shred a credit card or plastic coated material.
Feb 06, 2017 | Shredder Office Equipment & Supplies
Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does...
Some home office shredders have the shredding mechanism "permanently" attached with only the bin (tray?) removable. The entire machine has to be inverted to gain access for cleaning. Periodic cleaning is necessary maintenance as shredders of this type are not self-cleaning.
May 17, 2014 | Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
DO NOT BUY Durabrand PS-712CDB Shredder
Yeah, these are junk.
I actually have one that blew the control board and is not repairable... but all of my gears and such are perfectly fine.
Anyone want to buy mine? :)
Sep 28, 2009 | Office Equipment & Supplies
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
Dec 01, 2008 | Office Equipment & Supplies
FELLOWS PS 65C SHREADER
There is probably astripped or broken gear inside the gear box.
Nov 05, 2008 | Fellowes Office Equipment & Supplies
Jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
May 07, 2008 | Aurora Electronics AS882C (Cross-Cut)...
Can't get shredder to work
Please ... unplug your shredder before doing this.
It sounds like you were on the right track picking paper out of the gears. The problem is that the paper can get really jammed up in there, especially when you use the reverse.
I found that I needed to use a combination of a small screwdriver with at least a 3 inch long blade to push the jammed paper through. The I use needle-nosed plyers to pull the paper through the other side.
Hope this helps. Please let me know if it does.
Blessings,
-- Wes (wcbyers)
May 02, 2008 | Tech Solution TS-4500 Shredder
113 people viewed this question
k24674
