Question about Electronics - Others
Generator won't start. 10 HP B&S motor coleman 5000W generator (Powermate 6250 w/Briggs & Stratton GenPower 305 10OHV) Low Oil Kill Switch seems to be the problem (oil is full). In the back of the on/off switch there are 3 wires (white, black, red) If I remove the black wire - which I think is part of the low oil kill switch path - I can run engine just fine - but I can't turn it off unless I ground it out. This is an older model; Coleman sold out and Powermate is apparently gone to bankruptcy (so, not sure I want to bother with replacing parts - think this is a faulty design anyway). I guess I could just continue "as is" and manually grounding it out to stop it each time (not a great plan, gasoline safety wise). Can anyone offer a way to rewire the existing switch (see wiring above). I've tried different combinations of wiring, but haven't come up with a way to make it work and shut down via switch. I know the "low oil" kill switch is a good idea, but I think I can just keep an eye on the oil level (don't run it very often). Thanks, Will
  • WK Sep 02, 2010
    I think I've got my solution; not the best, but I'm okay with it.
    Disconnecting the white wire coming out of the sensor switch module allows me to use the on/off switch to operate generator.
    Each spring I will drain fuel and replace oil (and inspect/clean/gap plug, clean air filter as well as other basic maintenance) .
    During heavy use (which there probably won't be) I can check oil level more often.
    I'm the only one that uses generator.
4 Suggested Answers
  • 8 Answers
SOURCE: pool motor wiring
First and foremost, you need to check the Motor's voltage requirements, and match it to the voltage of the GFI you have connected to the House current.
The best way to do this is to use a volt meter at the GFI receptacle. Although it's likely the voltage at your GFI receptacle is 120Volts AC, you shouldn't guess on this. If you know what circuit breaker this GFI is using to get power.... you may be able to determine the GFI's voltage if you know how to distinquish between a single pole breaker and a two pole breaker (120Volts is derived from a sigle pole breaker, 240volts from a two pole breaker-which is twice the size of a single pole breaker).
Now the Motor: Most common Pool Motors are dual winding motors, on which, the voltage requirement could be changed to match the voltage supplied. On such a motor, there's a compartment where the cord is attached. Within this compartment, there's a configuration of screws or terminal points, and a related schematic which depicts the proper connections for each of the voltage options. By following these schematics, you will know how to connect the motor based on the available voltage supplied by your GFI protected receptacle.
Posted on Mar 23, 2009
  • 12 Answers
SOURCE: I have a Coleman Powermate pm0545007 generator
there should not be pinched wires...
if you mean "how do I bypass the low oil SENSOR" then the answer is to just disconnect it and tape up the end or snip it off in a location where it won't ground out...the way these engines kill the spark is by grounding the cdi coil wire...so fix that pinched wire and youre probably good to go...dont disconnect the low oil sensor unless its causing trouble....having low oil protection is good and might save you from blowing an engine
Posted on Jul 03, 2010
  • 35 Answers
SOURCE: What type of oil and its capacity should I use for
Use a 10w 30 or a 30w ND oil. Any brand will do and it should only take a quart. Check after about a 1/2 to 2/3 of a quart. If it doesn't have a dipstick just bring it up halfway in the filler tube.
Posted on Feb 02, 2011
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Electronics - Others Logo
120 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
