Question about Microwave Ovens
My sensor microwave oven got turned on for 45 min. with nothing in it. I turned it off when I realized what had happened, but now it won't start again. Do you know why? Is there a reset button?
  • Microwave Ovens Master
  • 9,086 Answers
If the fuse is good, it's probably an open thermostat or thermal cutout / thermal fuse on or near the magnetron or (less liklely) on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
For many brands and models, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please write back with your brand and model.
Some brands have a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 12, 2008
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
My GE Hvm1450dniww over the stove microwave won't
May be an internal fuse that has blown
Sep 13, 2012 | Microwave Ovens
Kenmore Elite Microwave has power but will not start?
switch if off completelty for approx 5 mins and then power it back on
Oct 26, 2011 | Microwave Ovens
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
I THOUGHT I SET THE TIMER-YET I HAD SET THE
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Blinking lights
unplug wait 5 min then turn back on
Dec 09, 2008 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
