Question about York Exercise & Fitness
I have a York Silver Streak rowing machine and the teflon rollers on the seat are wearing out. Can I get replacement parts.
2 Suggested Answers
  • 28 Answers
SOURCE: where i can find a seat for avanti is 400 rowing machin?
if you are looking for a seat for a rowing machine i would suggest checking amazon.com, craigslist, and ebay. I think that you will find what your looking for
Posted on Apr 09, 2012
Lexmark t-620 print spots
That usually indicates a worn heat roller in the fuser assembly. You can get a fuser from Amazon or other online site. They are user replaceable and run about $80-100. Do a search for T620 fuser and you will find them. Part number 99a2402 What happens is the Teflon coating on the fuser wears down which allows the toner to stick where is should not stick so it gets deposited on the paper in other locations and leaves spots.
Apr 18, 2013 | Lexmark Office Equipment & Supplies
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 10, 2011 | Exercise & Fitness
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
Teflon shoes in front keep wearing out
please use rubber pads better than teflon.
Oct 08, 2009 | Dryers
Worn seat wheels on Tunturi 202 need replacing
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Doc12 Upper Fuser Roller
that roller will need replaced along with replacing the wick and donor roll. The teflon wears and the ink sticks to the roller instead of peeling off.
Here is a link to order parts and get very good and professional people to deal with. This IS NOT me or where I work, but the best I found bar NONE for Xerox parts, When you call ask for Britt.
https://www.partsdrop.com/store/
Apr 26, 2008 | Xerox DocuColor 12 Color Copier
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Exercise & Fitness Logo
228 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
