Question about Hobart AM14-253 Free-standing Dishwasher
I have a AM14 (ML32614) Hobart dishmachine, my tech is having problems with the new style door switch (ordered 918320-00001) which is the round black barrell style. the old switch was a flat type switch. He is having problems mounting, please help.
SOURCE: I have a hobart dishmachine
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Posted on Mar 07, 2008
  • 68 Answers
SOURCE: dishmachine won't fill
Your problem is as straightforward as your observation, the unit is not getting enough water flow.
First, if your DW water is hooked up with a braided stainless hose, there is usually a screen in the end of it, (check both ends). It gets clogged with debris and chokes off the water. Make sure the line is not kinked.
If that doesn't work, you are likely having trouble with your fill valve. It is under the front kick panel. It has a large castle like upper cap. It is common for debris in the water to make this valve malfunction. It isn't too difficult to open up without removing. Just watch how it is assembled. If you pay attention, it's easy. If you have a booster, the hoses are very brittle with age.
And otherwise, the fill valve may be bad. REMEMBER, verify your supply water flow where it connects to the machine first. Don't assume. You could have a pressure regulator or a line strainer that is part of your supply line. They do fail. But that's a plumber's fix, not a technician.
Posted on Jun 21, 2008
bigg t
  • 640 Answers
SOURCE: incorrect wiring on a heater
Is this single or 3 phase? What happened?I'm a hobart tech.
Posted on Jan 25, 2009
  • 109 Answers
SOURCE: hobart am14 water runs through it all the time
I asume you are referring to water running from the rinse arms all the time.
You will need to check the fill/rinse solenoid. It may have debris holding it open, or is worn out. For the correct parts, have your machine ML number and look on www.hobartservice.com in the parts section. Use the ML to get your specific drawings and part numbers. Call 1-800-444-4764 to reach the nearest Hobart officeand ask for parts. There are quite a few variations of solenoids throughout the AM14 build span, but all have a repair kit if the body is not worn. Check the rubber end of the piston for wear. It comes in the kit.
Posted on Aug 08, 2009
  • 110 Answers
SOURCE: Hobart dishwasher Am14, rinse cycle is too short.
no rinse time can't be adjust on the am-14 modelit is built in main board non variable
Posted on Jan 11, 2010
Hi on one of our offshore rigs we have a AMX-16 dishwasher we require a parts manual for this machine so that we can order a new bottom spray bar we would also like to have a user manual for this machine
Hi rrydlewicz
I am on the Total Dunbar in the North sea Northern sector. I have an intermittent fault code problem I would like to solve, did you ever get hold of a manual for the Hobart dishwasher?
Drop me a line at colburn1@hotmail.com
Cheers mate
CBD. Elect tech
Mar 11, 2010 | Hobart AM14-253 Free-standing Dishwasher
Dishmachine lx30h
Did you solve your problem?I'm a hobart tech and can step you through somethings to check.
Apr 12, 2009 | Hobart Dishwashers
Random starting by itself
Does this happen all the time?Is the door closed and are they bent?If you stand in front of the unit on the right door up top is there a grey looking capsule (door magnet) is it loose?Next to it should be another capsule which has a switch inside.I would make sure these 2 capsules are tight.Let me know.I'm a hobart tech.
Apr 11, 2009 | Hobart AM14-253 Free-standing Dishwasher
The water temperature does not get over 98 degrees.
Did you solve your problem?I'm a hobart tech and repair these often.Let me know.
Apr 09, 2009 | Hobart 40 in. AM14-254 Free-standing...
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
Dishwasher does not spray hot water
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Feb 25, 2009 | Hobart AM14-253 Free-standing Dishwasher
Rinse arms
Sorry for the late reply, did you solve your problem?i'm a hobart tech and give you some things to check.
Feb 16, 2009 | Hobart AM14-253 Free-standing Dishwasher
Door tension spring broken.
The columbus hobart branch should have this part.Need any more info let me know.
Dec 08, 2008 | Hobart 41 in. AM14-255 Free-standing...
Hobart ar14
Do you mean the door switch/magnet?
Oct 17, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart AM14-253 Free-standing Dishwasher Logo
53 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
