Question about Air Tools & Compressors
I have a proforce VPP0200604 air compressor made by colman I need air filter plastic, oil fill plug plastic, and the oil level sight glass they said no parts are avaible
5 Suggested Answers
  • 98 Answers
SOURCE: need a unloader valve for a ProForce model no.
Need to know the desired pressure for your compressor, please dont exceed the compressors capabilities
Posted on Jul 21, 2009
harlan301
  • 205 Answers
SOURCE: i need a part for VPP0200604 PRoforce air
that made by powermate which is out of business no part. you can check with pramc co which owens that division know. 800-445-2276
Posted on Oct 14, 2009
Porrelli
  • 167 Answers
SOURCE: how do you check oil level on a u20 ir compressor
Hi
No mate, you check it when the pump is not running.
Don't over fill it or it will pump oil into the tank.
That's bad news if you want to paint.
The middle of the sight glass is the correct level.
Don't let the oil get too low either.
The pump lubricates by a dipper on the bottom of the conrods. Too low an oil level starves the top end of oil and causes premature wear.
Regards Andrew Porrelli
Posted on Dec 07, 2009
nampaboat
  • 150 Answers
SOURCE: I broke the wheel on my Proforce (VPP0200604) air
The wheel kit has been discontinued so I would go to http://www.mastertoolrepair.com/advanced_search_result.php?keywords=wheel&x=23&y=9 and see if you can match one up.
Posted on Mar 13, 2011
Compressor showing high air end discahrge temperature, what amy be the probable reasons for that and solutions to rectify it?
Since I don.t know brand or model I will give you most common problems and answers.
Low oil level. Don't trust sight glass. Remove fill plug and look at oil level.
Dirty oil cooler. Cooler needs to be cleaned. Depending on how dirty cooler is it may be blown out with air or pressure washed.
Bad oil thermostat. Remove and replace thermostat.
Jul 29, 2017 | Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
I have an old type 30 model ingersoll rand air compressor. It has not run for years, we just wired it up and ran it for about 5 minutes. After that, I thought I better check the oil level... There does...
Alot of the older units did not have a sight glass. They had a dip stick on the fill plug. Over the years they broke off or the oil fill plug was replaced with a newer type that does not have the dip stick. To answer your question dip stick or not I always fill with oil to the bottom of the threads on the fill plug. You should remove the plug and check the oil level before each use on and older unit like this until you have a good handle on how much oil it uses. you may also be able to remove a plug usually on the front of the case lower left side and install a sight glass or low oil level switch. Have a good day!!
Nov 12, 2011 | Ingersoll Rand - Rand Type - 30...
What level should the oil be in the view sight and what type of oil should be used to fill if needed?
Your oil level should be right in the middl of the sight glass as per the type of oil I'm sure Craftsman has there brand of oil they suggest. But any good quality compressor oil will work.
Jun 25, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Hi I have a coleman pro force air compressor and the fan blade on the motor came lose, do you know where I can get a new one. The center hole is egged out and some of the finns are broke off. The serial #...
This compressor appears to be an obsolete model, and the parts diagram (https://mastertoolrepair.com/air-compressor-parts-vpp0200604-vp0200604-p-14827.html) does not show a part number for the fan blade. This means it was either a subcomponent of another assembly -- probably the pump unit itself -- or it is out of stock permanently. I'd suggest you take the old blade and fill the mounting hole with epoxy, then after it cures, drill a new hole and reinstall it. Otherwise, your compressor is likely "toast."
Dec 26, 2017 | Coleman Proforce 6 Gallon Air Compressor
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
How much oil does the 2475 hold
A 2475 has no way to tell how much oil is in it other than removing the oil fill plug and looking unless a low oil level switch has been installed. You should fill this unit to the bottom of the oil fill plug threads. It's less than 2 quarts. IR does have a spec sheet that tells the exact amount. I don't have it available right now!
Nov 03, 2010 | Ingersoll Rand 2340/2475 Electric Air...
I need a part for VPP0200604 PRoforce air compressor
Oct 14, 2009 | Coleman Proforce 6 Gallon Air Compressor
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
Air Tools & Compressors Logo
247 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
