Question about Samsung Office Equipment & Supplies
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the glass, no line appears. How can I fix this?
    Scholar:
  • 44 Answers
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Posted on Sep 02, 2010
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper feed does not pick up properly
Clean the tray paper feed roller rubber,or try using the bypass tray(manual alimentation).
Apr 22, 2013 | Samsung SCX-4521 All-In-One Laser Printer
I hve the samsung scx 4521. and when i am trying to photocopy i am getting blank copy. and no content is coming. only i am gettting a blank white paper.. please give me a solution for this.thx
If the problem is coming only when coping thats mean there are few things that could gone wrong.The first thing to do is to check the scanner lamp.Open the top cover and press the copy button.The scanner should start moving and flashing.If the scanner is moving but no light i coming out of it means you scanner is broken or the cable(scanner-forrmater)is broken.If the scanner is moving and flashing but there is no image means the scanner forrmater board is broken.Please replay if you need futher help!!!
Nov 22, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Need to replace the transfer roller on my SCX-4521f printer b/c when I try to scan and copy through the feeding part, the copy that comes out have a vertical black line runs in the middle of the page. how...
hello
i think this is a problem of toner cartridge replace the toner orremanufacture your toner .if didnt solove it.
get small piece of cloth and sock in to the water and crush it and wipe the transfer roller. then again get cloth and wipe it
Aug 10, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Have a Samsung SCX-5315F All-In-One that has a line running down the page when you copy using the document input tray. Clean copy when using the flatbed. I have cleaned all the glass thoroughly.
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Feb 18, 2010 | Samsung SCX-5315F All-In-One Laser Printer
Samsung scx-4521 printer driver
try this site...then check the windows support when u download the driver
http://www.driverstock.com/Sapphire-SCX-4521-driver-download/19-26-4784/
Sep 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung scx-4521 f
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
Jun 27, 2006 | Samsung SCX 4521F All-In-One Laser Printer
156 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
