Question about Electrolux Kitchen Ranges
My ovene model # E36DF76EPS the oven not working the power is on and two blu light blinkng 2-4 from the top wate culd be the problem
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow regarding your query:-
http://www.repairclinic.com/Microwave-Troubleshooting#Itdoesntworkatall
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 02, 2010
Why is my Wolf oven apparently getting no power? Stove top lights but oven won't light and no power to panel.
Not sure about your make , but if 1 half of the unit works ( The top elements in your case) and the oven doesnt, I would suggest that there may be 2 fuses in your meter box ( If the oven is wired across 2 phases) or there may be 2 fuses in the back of the oven and the fuse that protects the oven has failed. If unsure, be safe and get an Electrician or a stove technician to sort it out for you.
Sep 28, 2015 | Wolf Range Kitchen Ranges
Electrolux E36DF76EPS Why does the lock light keep flashing ( note oven works normally )
Hello Thecarsons, thank you for your post!
I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Jun 10, 2015 | Electrolux Ovens
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Replaced oven igniter, but oven still not working.
culd be a relay on the clock assy not closing , or the safety valve has gone bad. the valve is checked by checking for continuity through the valve itself( it should have continuity through the two wire connections oon the one side of the vavle). as far as the relay on the clock cosing, with a good valve, you should get 110v to the ignitor when bake is selected( you should hear a faint click from clock a sec or 2 after pressing start)
Apr 10, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
50 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
