Set won't light up - hls5686w
I was watching the tv one night and it suddenly shut off. I tried to turn it back on and it keep going though cycles until finally it stopped, the all three lights where flashing. I went to my owners manual and saw that it could be the bulb went out.
I orders a bulb from a company on ebay and recieved it this Friday. I removed the old one and replaced it with thenew one i recieved. Needless to say, NO LUCK. I made sure that the case was securely placed into the space provided assuring that both pegs where sticking out of the holes next to the screw. I made sure that the access door was securely placed , as i read that the set would not turn on if it sensors picked up and open door. I then plugged it back in and turned the set on, but it still will not light up the bulb. I goes through two or three cycles and then stops, with all three lighsts flashing.
Questions are:
Did i get a bad buld from this company?
Is there something else that could be wrong with the set?
Should i call Samsung and have them come out to see the set?
    Scholar:
  • 131 Answers
Your new bulb is most likely ok. maybe bad thermo protector near lamp. or bad ballast or worst case light engine.Call a local tv shop to come out and look at it,
prices as low as 160 for thermo to worst case light engine 600
Make sure you closed the cover that gos on lamp there is a switch that will pervent tv from coming on if you dont have cover on.
Thanks doctor video
Posted on May 10, 2008
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
I have a 37LG505H-UB LG LCD TV and when I watch it, it all of a sudden starts scanning for channels on the RF input even though I have it hooked to HDMI on the STB. It won't stop and when I turn it of
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 03, 2017 | LG Televison & Video
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
I was watching tv last night when all of a sudden the screen started going fuzzy then it just switched off and now it wont switch back on and the red light just flashes is there anything i can do?
30 YR SEVICE3 TECH
TRY UNPLUGING SET FROM THE WALL FOR ABOUT 2 MINUTES PLUG BACK IN AND TRY THE SET. IF SET DOES NOT COME ON TAKE IT TO A QUALFIED SERVICER.
APGONZO
Jan 12, 2009 | Bush 5693D 24" TV
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Green Screen
Your picture tube is bad,pull back off/ unplug crt broad on neck of tube make sure it does not touch anything ,turn set back on if set stays on tube is shorted!
Dec 18, 2007 | GE 13R100T 13" TV
RCA CTC203 No Colour in the Video IN or Svideo
It is possible that while programming the remote you got into the menu on your TV and adjusted the color control. Go back into the menu and find the controls for color, contrast, tint and etc. If the color bar is all the way to the left, then adjust it to go to the right until you get enough color. This is just one possible solution. Hope this corrects the problem.
Dec 05, 2007 | RCA Universal Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
