Question about Sharp Comfort Touch AF-R120EX Air Conditioner
I have a Sharp model number AF-S125FX that shuts off and I get the E1 message . I have cleaned the filter and tried the E 1 solution that was listed for a differant model number and have had no luck. unplugged the unit,pressed the power on and held until it went through the steps ,unplugged again,plugged the unit in again ,powered it up and it will run for about five minuets then shut back off
  • Sharp Master
  • 17,130 Answers
Please check the relay of the comppressor and also the capacitor of the compressor. Check also if there is any issues in the controller section that can bring in the errors.
open and tigten all connectors, take a test on relays to manually switch on fan and compressor to confirm their worrking. the check for the micro controller's functiioning.
Posted on Sep 02, 2010
Shuts down and gives me failure E 1 on the card and will not start
E1 = The air filters need cleaning (after 720 Hours use)
It will shut down until you clean the filters & reset the E1 alarm code.
To do this you need to:
Pull the Air Con appliance lead out of the power outlet in the wall.
Remove & Clean the air filters & then put the cleaned filters back in machine
Before plugging back in you Push & Hold the Power button on the Unit
THEN while holding the power button you PLUG the lead back into the wall.
Keep Holding the power button until you hear the unit emit a beep (hold for approx 5 secs)
Then disconnect the power supply lead again.
Then Plug it back in again & turn on
It should be cleared & working well.
Good luck
Aug 10, 2013 | Sharp AF-S120FX Air Conditioner
I have a Sharp AF-S80FX A.C. unit. Whether on cool or fan the unit keeps tripping the breaker on the plug with an E1 message. The filter has been removed and cleaned, but it really wasn't dirty.
small_16_7.jpg For a detailed Air Conditioner illustration, click below.
redarrow.gif Window
It doesn't turn on at all
The fan runs but there's no cold air
The air is cool but doesn't seem cold enough
The unit never turns off
There is water sloshing around inside
The unit tries to start for a few seconds and then quits
A motor is running but there is no air blowing
The unit rattles loudly when it turns off
Water leaks out the front of the unit
The air smells musty
Note: If your repair problem isn't listed, click here
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
Jul 10, 2008 | Sharp Heating & Cooling
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
Sharp AF-S125FX air conditionaer doesn't work when I plug it in
Sounds like there is something grounded inside the A/C unit or a fan or the compressor locked up. Could also be a motor winding in the compressor or one of the fans shorted thru.
May 02, 2010 | Sharp Heating & Cooling
Ei flashing display unit power cutoff
E1 MEANS FILTER CLEAN AND THEN CHECK IF STILL ON THIS IS ASOFTWARE PROB CAN BE DONE ONLY BY THE SEALER SUPPORT.
Aug 31, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
227 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
