Question about Peg Perego John Deere Gator HPX Ride on Toy
The Peg Perego John Deere Gator accelerator petal is off and the red wire that comes from the front is cut and apparently bad. I dodn't know what to call that replacement part and I haven't even looked to see what it leads to.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
SOURCE: PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Posted on Oct 17, 2008
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
  • 156 Answers
SOURCE: Peg Perego John Deere Gator not working at all
It sounds like you need a pedal switch or it has a loose connection in the wires. It is a specific Peg Perego Switch that will fit under the foot pedal. I have a gator that was doing the same thing so i replaced the shifter switches and the foot pedal switch, but I bet you could start with just the foot pedal switch.
I bought mine at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html but you could also call them as well.
Hope this helps
Posted on Apr 30, 2009
12v wiring diagram for perego johndeere gator
Below is a the wiring diagram for the Peg Perego John Deere Gator HPX. I also included the parts diagram.
If the images are too small you can find them online (as well as replacement parts & manuals from a Peg Perego service center) here: http://peg-peregoparts.com/diagram.php?num=IGOD0055
see also: http://peg-peregoparts.com/vehicle.php?num=IGOD0055&display=overhaul
Wiring Diagram
c321785b-edfb-474f-aeb5-b95b778733bd.jpgParts Diagram
18872932-1308-4a2d-be44-39e68011f567.jpg b
Best of Luck!
May 10, 2012 | Peg Perego John Deere Gator HPX Ride on...
Battery is good but the gator wont move when pushing the accelerator
A lot of times the problem is with the accelerator switch going bad. To check, remove the red and white wire form the accelerator switch and connect them together. If you gator moves, then your switch is bad. You can get a replacement at mypegperegoparts.com
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
I'am Looking for a diagram for a Plunger Fuse onthe gator 4x2
The wire sequence is red, white, blue.
The red is the farthest from the other two.
If it is a peg perego switch plunger style then this will work.
Hope this helps
Jun 22, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
Dec 21, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego John Deere Gator HPX Ride on Toy Logo
89 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
