Question about Sony Ericsson K800i Cellular Phone
Battery failure you say flash the software if the red light is flashing? how do you do that?
    Problem Solver:
  • 10 Answers
This problem i also had if the phone is not swtching on and Through the IR if it blinks red light u have to flash,,,, but they flash this in a diferent way cos the normal way the phone does not ditect, u take to a close repair centre and ask if they can do it, in my country there is aplace they charge 20 US dollars,
Posted on May 13, 2008
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
Potterton suprima 30 80 keeps tripping out red light flashing
Hello, like your failure is due to the generator is generally low and the battery energy storage performance degradation, it is recommended that you check the engine power and the energy storage performance of battery, as well as the link of the body by iron wire, according to specific situation for repair.
you want solve this problem please :diagnostic tool
Mar 22, 2013 | Cars & Trucks
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Jan 05, 2010 | Sony Ericsson K850i Mobile Phone
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My printer is flashing two red lights and the
Communication error is saying that the computer & printer is not communicating. Try uninstalling the driver/software and then download updated drivers/software for the o/s you are using from the support link on epson.com. Install the updated drivers/software and see if it works. Hope this helps.
Jul 02, 2009 | Epson Stylus C86 InkJet Printer
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
Mar 12, 2008 | RIM BlackBerry 7290
Sony Ericsson K800i Cellular Phone Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
