Question about Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 808A-replacement aerial antenna
Radio took a dive off a shelf- telescoping aerial broke. Is there a replacement part for this? If so, how does one obtain one and how easy is it to replace?
  • 17 Answers
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
Posted on Aug 04, 2009
What does a flashing E in the LCD mean?
Try checking the correct power supply, and batteries. ("E" = error)
Sep 24, 2014 | Sangean ATS 808A AM/FM/SW Radio
Troubleshooting
My Sangean ATS800A wont come on, battery shows
Jun 17, 2013 | Sangean ATS 808A AM/FM/SW Radio
NEED REPLACEMENT SW ANTENNA
Sangean America, Inc.
Service Department.
2651 Troy Avenue South El Monte, CA 91733
Phone: (888) 726-4326
Jul 13, 2011 | Sangean ATS 909 AM/FM/SW Radio
I want to add an external antenna, is this product available to be purchased, if so from what stores and approx. how much will it cost. My Radio is a Sangean ATS 808A. Also, is a 220 Volt power pack...
Hello eab.... I would begin by looking at Radio Shack. Take the radio in with you. The prices cover a wide price range depending on the range and quality. Joe
Thanks for choosing Fixya!
Feb 26, 2011 | Sangean ATS 808A AM/FM/SW Radio
My Sangean ATS 808 AM/FM/SW Radio reciever shows a flashing E on startup and won't operate. Any answers on resetting or other solution?
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Oct 17, 2010 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
Old Shortwave Tabletop Radio
HELLO,
TO SOLVE YOUR PROBLEM YOU NEED
TO GET A SW ANTENNA TUNER.
THE ONE I BOUGHT IS
MFJ-956 TUNER
THIS WILL PREVENT THE WIRE THAT IS
NOT TUNED TO BE TUNED TO THE RIGHT
BAND 11M TO 160M
RONS ELECTRONIC
Oct 16, 2007 | Sangean ATS 808A AM/FM/SW Radio
No reception sometimes
Either this is typical shortwave reception characteristics, or you intermittent antenna connection.
Sep 23, 2007 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 808A AM/FM/SW Radio Logo
588 people viewed this question
Top Sangean Audio Players & Recorders Experts
Mark Schmit
Mark Schmit
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
